Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The top drawer is binding.. it is extremely hard to close?
  • Fisher and P... Master
  • 3,247 Answers
Either the drawer seal is damaged (top edge of housing from inside) or the drawer has come off the rails.
Remove the front cover (pull out 2 plastic pins on each side) and pull the drawer out. Inspect if it is still on rails and also check the seal. You should be able to push it back a little with your fingers. If hard or rigid, then seal mechanism needs fixing.
Posted on Sep 03, 2010
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
GE under oven drawer sags, won t close properly, big gap exists between drawer face and oven door.
Don't look too hard for a solution to the problem. I have seen this same issue with three or four other manufacturers brand stoves. Not sure why they can't build a drawer that won't bind and stick, but they seemingly cannot.
Jan 06, 2015 | GE Stove/Oven/RanWhite Glass Top -...
Milk drawer won't close
its the switches there is 2 one on top and one at the back the milk container is not making contact properly because the container needs realigning
Mar 12, 2012 | Saeco Primea Cappuccino Touch Plus Coffee...
I have the freezer set at 3. There is ice forming all around the door and snow like frost on the food.
Frost buildup on food and ice around the door is due to warm air infiltration. This sounds like a door closure problem. Be sure that nothing is interfering with the drawer as it closes. Be sure to open the upper door and look down at the drawer top to see that the gasket is hitting the steel frame of the cabinet. Look all the way around the entire drawer front checking the seal.
Also open the drawer and hold it as it closes, so that if there is any food product binding it you will see it get hung open.
Good luck.
Jun 13, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Top drawer of 2 drawer f and p dishwasher was very hard to slide open and have to really push hard to close, like something is binding
Hi,aside from any obstruction is thet DishDrawer® square and level?. Is the DishDrawer® fastened securely to the cabinetry to prevent flex or movement? If not, the square geometry this appliance requires with affect drawer performance when opening and closing.
This is the most common cause for your problem. I'm not 100% sure, but it is something to take into consideration. Just a thought.
Feb 07, 2010 | Fisher and Paykel 24 in. DD603H W Built-in...
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Cleaning dispenceser drawer can't open
Unfortunately the screws which hold the dispenser to the machine are located behind the drawer which at present you are unable to open. As you say you have the top cover off, you might try shining a light into the top side to see if you can see where the hang up is, and then drilling a small hole in the plastic and poking something through to move or dislodge the blockage. A small hole could be resealed with foil tape or silicone, or the dispenser housing replaced once you are able to remove the drawer and access the mounting screws.
Nov 14, 2008 | LG WM-2277HW Front Load Washer
The top drawer of my dishwasher has just become extremely difficult to open or close, bottom drawer is fine. Can anyone suggest what the problem may be?
Sorry if this seems so simple, but try unplugging the dishwasher and plugging it back in. Ours had the same problem after our house cleaner ran it, it turned out that the cycle had been interrupted and the top-seal motor had not retracted the top-seal.
That worked for us, good luck w/yours.
Apr 17, 2008 | Dishwashers
Drawers Stuck
the lid acuators have been up dated(due to this problem) though i find it hard to beleive both are bad
Jan 06, 2008 | Fisher and Paykel 23 in. DD603H SS...
Sub-zero 550 reefridgerator top freezer bottom - refridgerator door not staying closed
Just a guess, but I would check the gasket on the door. They can go bad or get distorted and bunch up and cause the door to bind and not close properly. Also check that the fridge is leveled properly. Will the door close if pushed? Will it stay closed?
Dec 25, 2007 | Sub-Zero 650 / O Bottom Freezer...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
125 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
