Question about GPS
At first there was warning light come on at the panel display. At the same time lost power to the engine. I checked the alarm symbol at the owner's handbook, it mean emission control system. I tried to check the three ignition coil that supply to the six spark plug. I found out that one ignition coil has no high voltage that supply to the two spark plug. But it was only sometime before and now it become a permanent. My problem is I don't know the location of the said emission control. Will you please teach me where I can fine it.
  • 19,396 Answers
The light indicates that a high engine or evaporative emissions had been detected by the O2 sensors. If the light is blinking instead of steady, that means that the fault detected may cause damage to the engine.
The emission system is the exhaust plus O2 sensors, located on the exhaust pipe, before and after the catalitic converter. This is probably the symptom of the problem, rather than the cause. If problem was simply the emission system, engine would crank, and you would get voltage from both coil packs.
If one of the coil packs has no voltage, that is the problem. Either the coil is faulty, or there is a problem in connection from coil to PCM and ignition. Depending on the car model, if coil packs are identic, they can be tested by swapping them. A better test is reading voltage in to coil pack.
If you have an OBDII scanner you can also read stored engine codes, they often reaveal more on the problem.
Posted on Aug 27, 2010
Why does my darango shut off while driving?
If it's an exclamation point inside a triangle, it's called a master warning symbol. This is the Master Warning Light symbol. If this light is on, there will likely be text displayed as well on the instrument panel, or another warning light. Look for text in particular. It could very well point out something as serious as low oil pressure. If the engine is not running, you can't very well check your gauges, but you may have lost all oil pressure or overheated the engine. Recommend you consult a mechanic familiar with your model.
Oct 14, 2016 | 2003 Dodge Durango
I have a P reg Suzuki Swift Auto. On the dash board I keep getting the (!) sign. Sometimes it goes but reappears. What does it mean?
we dont know UK reg codes, this forum is California, so....
use real Gregorian dates. years. for best of all help
hey thanks for the oblique clues. reg + !
we dont have ! warnings on ours.
but is (was) in the operators guide> lost that?
reg code P (iso ) is
P 23px-flag_of_portugal.svg.png Portugal warning on many cars are designed for target country.
so?
with special operators guide for you.
ours is here.
and endless list . it seems
on or cars if at all, its master warning
means to look at all other lights and gauges for wrong readings.
but>?????
quote:
This is the Master Warning Light symbol. If this light is on, there will likely be text displayed as well on the instrument panel. Look for the text. It could very well point out something as serious as low oil pressure. However, despite the serious look to the symbol, it is generally associated with simple reminders such as a door ajar or that it is time to change the oil. master_warning_light_2.gifThis same symbol, an exclamation point in a triangle, in yellow or amber has been used by European vehicle manufacturers to indicate a fault in the vehicle's Stability Control System. The vehicle can be driven with caution, but without the benefit of the advanced electronic control system. See your dealer as soon as possible.
buy the lost operators guide and not need to google seach every time a light flashes. nor get stranded. with no 3g.
Jan 26, 2015 | Suzuki Cars & Trucks
Warning exclamation point light on
the owners manual lost? its there
read it again. it even has photos of all symbols.
here it is,, just READ it.
http://justgivemethedamnmanual.com/toyota/toyota-corolla-owners-manuals/
if it is brakes, then check the brake fluid level, first. as it says.
Nov 27, 2013 | 2001 Toyota Corolla
Last night while driving down a hill i got a warning light that blook like a turtle
Your owners manual should have a description of the symbol.
It means the battery power is low and you only have engine power - so take it easy as long as the warning symbol is present.
Jul 31, 2012 | Cars & Trucks
I have a 2004 Jeep Cherokee Laredo. An indicator (with a symbol of what looks like a radiator) below the low fuel indicator (bottom left had side of the dashboard) lights up and remains on. I have checked...
2005 Instrument cluster layout
1. Speedometer
2. Brake warning light
3. Turn signal indicator light
4. High beam indicator light
5. Malfunction Indicator Light (MIL)
6. Airbag warning light
7. Anti-Lock brake warning light
8. Tachometer
9. Security alarm indicator light
10. Oil pressure warning light
11. Electronic Stability Program (ESP)/
Traction Control System (TCS) indicator light
12. Tire Pressure Monitor warning light (base)
13. Temperature gauge
14. Electronic Vehicle Information Display
15. Tow/Haul indicator light
16. 4WD Low mode indicator light
17. Seat belt reminder light
18. Cruise control indicator light
19. Odometer/Trip Odometer
20. Transmission gear indicator
21. Fuel gauge
22. Electronic Throttle warning light (5.7 Hemi)
23. Front fog light indicator light
24. Voltage warning light
Jun 05, 2011 | 2004 Jeep Grand Cherokee
A flashing orange symbol shows up on dash panel and I don't know what it is-\r\n--can u show me some examples so that I may know what it means? 2000Dodge Intrepid
I don't have any pictures but if it's flashing it's probably the check engine light (some vehicles show this as a symbol instead of the words). If it is and it's flashing, that indicates the engine is missfiring and could potentially damage the catalytic converters. A diagram of all the warning lights is shown in the owners manual with a nice description
Oct 16, 2010 | 2000 Dodge Intrepid
Missing a owners manual
take the vehicle to the dealer. ths is what the owners manual would tell you to do for the check engine light.
Aug 15, 2009 | Mitsubishi Montero Sport Cars & Trucks
Warning light
IT SOUNDS LIKE YOU'RE REFERRING TO THE TROUBLE SYMBOL FOR HEADLIGHT/TAIL LIGHTS. THE PROBLEM CAN BE WITH A BULB, FUSE, ELECTRICAL CONNECTION. CHECK YOUR USER'S MANUAL UNDER HEADLIGHTS.
Jul 08, 2008 | 2003 Audi TT
GPS Logo
32 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
