Question about Xerox Phaser 8400 Laser Printer
Printer prints, but ink does not adhere to paper
Any ideas? I am assuming it is because one of the heating lamps has gone out.
  • Anonymous Jul 15, 2008
    xerox 8400 error code out of ink
    President:
  • 2,072 Answers
Most of the time it is the paper heater assembly not being hot enough.
Althoug that is a problem most associated with the paper your using.
If heater is out, normally the machine faults out. But still as seen in the documentation , a heater may not be in position or functioning properly.
Check the media type and finish.
If the media appears glossy, replace the media and reprint.
Does the problem persist?
Check the Preheater and Drum temperatures.
Run the Service Diagnostics Temperature test.
Are the temperatures within specified ranges (approximately 60 to 62 degrees Celsius)?
Check the position of the Drum Temperature Sensor.
Is the sensor positioned properly?
Posted on May 06, 2008
My phaser 6180 color printer, toner not adhering to paper
hi.it could be your print cartridge.end of life.and very costly
Nov 19, 2013 | Xerox Phaser 6125 Laser Printer
Problem with paper feed - all sheets come out wrinkled with smeared ink print
Sounds like your fuser is bad, ink is not adhering to the paper and building up on a roller that is causing the paper to wrinkle.
Oct 21, 2010 | HP LaserJet P3005n Printer
HP Laser Jet P3005 Printer is printing very slow
It is usually dirty and old fuser. It would takes longer time to heat up and also triggering error messages. Try changing that.
Feb 15, 2010 | HP LaserJet P3005n Printer
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
The ink wont adhere to the paper. I know it's not a paper issue cos we are just using plain paper. It is smeared and has white spots on it where the ink came off.
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 18, 2009 | Konica Minolta magicolor 7450 Laser...
Ink won't adhere to photo paper
you probably need a special kind of ink but im not sure
May 18, 2009 | Brother MFC 420CN All-In-One InkJet...
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Printing options have disappeared (re plain paper; glossy paper; CD etc)
here is ur fix
The paper types available in the driver are dependent on which type of black ink cartridge is loaded in the printer. If the Photo Black ink is loaded, you should have various glossy paper choices. If the Matte Black ink is loaded, you will have a choice of plain or Matte paper types. Once the cartridge is switched, you will get the corresponding paper choices.
Mar 09, 2008 | Epson Stylus Photo 2100 InkJet Printer
Sticky photo printing and poor quality
GO IN TO PRINTING PREFERENCES on computer AND CHANGE SETTINGS TO MATCH THE KIND OF PAPER YOU ARE USING OR CHANGE PRINTING PREFERENCES TO PHOTO WHEN PRINTING PHOTOS
Sep 10, 2007 | Dell 924 All-in-One InkJet Printer
Xerox Phaser 8400 Laser Printer Logo
50 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
