ASUS P4SGX-MX Motherboard Logo
Anonymous Posted on Aug 27, 2010
Hi, I want to increase the 256MB RAM in my P4SGX-MX motherboard to 2GB. What is the most compatible RAM for it?
Anonymous
Level 2:
New Friend:
  • Expert 85 Answers
  • Posted on Aug 27, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
85
Questions
Helped
12201
Points
195
DDR ram is used in this i think the cost of 2gb ram must be around 50$
Testimonial: "Thanks for your prompt reply."
A7v8x-mx 2GB (2x 1GB) don't recognize
Sounds like you have run into a compatibility problem between your RAM and motherboard. These kinds of problems have been very common and that is why most motherboards have a supported memory list. Usually if the RAM does not work properly you can try reversing the slots that they are plugged into and make sure that your motherboard is set for the proper voltage and speed for the RAM. If it still does not work then you would most likely need either different RAM or a different motherboard.
2helpful
Asus p4sgx-mx audio driver
  • Model: P4SGX-MX
  • Size: 2.09 Mb
  • Date added: 16-Apr-2009, 07:43
  • Manufacturer: ASUS
  • Device type: Motherboard
  • Operation system: Windows XP
  • MD5: cc496c9fc693f22e1e02bccfcc0e91b9
  1. http://nodevice.in/driver/P4SGX-MX/get54804.html
  2. http://www.nodevice.com/driver/P4SGX-MX/get54804.html
  3. http://www.driversberry.com/drivers-P4SGX-MX-fGpKoZZ1US.html
Asus P4SGX-MX Audio drivers
Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3665 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 18 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 2 MB Supported OS: Windows 98SE, Windows ME, Windows 2000, Windows XP
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 4.2.0.82 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3620 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Model: P4SGX-MX Category: Motherboard Type: Audio Vendor: Asus Version: 5.12.01.3533 File size: 3 MB Supported OS: Windows NT
buttondl.pngDownload now Check out this page for a P4SGX-MX Audio driver download. Here you may choose your Asus device driver software. Please keep in mind that you should choose a proper P4SGX-MX Audio Asus device driver. First of all you should know your operating system, vendor name and device model. If you don't know what device you have inside try out this. Try to search for your device driver using PNPid. Open Control Panel-system-hardware-device manager then double click and click details. Use this long digits and letters line to find out what device you have and driver for it. Some drivers on our website may be packed with winzip or winrar programs.
Mi PC tiene: placa base ASUS P4GE-MX-procesador X86 family 15 mod.4 stepping 1- un HD de 80GB y memoria RAM DDR 256MB. Quiero ampliar mi memoria a 1 X 2 de 560MB (1GB) y instalar HD de 120GB. Es posible
S?, usted puede actualizar su equipo. La placa base es compatible con la memoria DDR1 tipo PC1600/2100/2700 2GB max. Es necesario IDE tipo HD. Buena suerte.
Hi can anyone tell me what type of RAM is used in the Asus P4SGX-MX Motherboard please. Chris.
Your motherboard has 2 (DDR) and 2 (SDRAM) slots. DDR and SDRAM memory modules cannot be used simultaneously, and the maximum capacity is 2GB of RAM. So you can put in either DDR or SDRAM modules.
http://www.memoryc.com/asus/13039_p4sgxmxmemory.html
2helpful
3answers
2helpful
Asus p4sgx mx motherboard
Asus has driver software for allot of operating systems. Click the link to open Asus;
http://support.asus.com/download/download.aspx?modelname=P4SGX-MX&SLanguage=en-us
You will need to pick your current operating system from the drop down menu & click the search button. Than all the drivers for the Asus P4SGX-MX mother board will be shown. Click the + sign to open listed drivers. Choose the latest not the oldest drivers.
Thank you for using Fixya!
Mike
5helpful
3answers
Adding memory to Asus p5v800-mx motherboard
if they are compatible with your motherboard, different versions of RAM do not conflict
Compatible video card
Hi sbagator, the Asus P4SGX-MX board can use (1.5V only), AGP4x graphics card. You can find some here at this link.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=879&name=128-MB-4X-AGP-Video-Cards
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102085
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102734
A 1.5v video card has two seperate copper connectores, not counting the tail lock. If there are three seperate copper connectors not counting the tail lock. It is not a 1.5 volt video card. So check out the picture of a card before you buy.
This next link will take you directly to Asus web site for your board. Manual, drivers ect.
Good Luck!
Drop me a line & let me know how it goes!
Mike
2answers
Intel D845GBV Motherboard Problem
PC1600 runs at 200MHZ and PC2100 runs at 266MHZ..
Since your motherboard only supports a max of 266MHZ, I would recommend that. (not to mention that PC1600 is pretty much obsolete)..
2nd, you motherboard supports a MAX of 2GB Total ram.. So, you could install 1GB + 256MB.. But why not go for 2xGB?
The price for a 1GB stick of PC2100 is around $75-125 CAN. Not soo cheap anymore...
L2cache
Unless Asus have an updated BIOS for this motherboard and lists it as compatible then it probably won't work.
The Prescott CPU's (ones with 1MB cache) can use more power so if your motherboard doesn't list it as being supported it will not provide enough power and won't boot or could have problems with crashing even if it does boot.
The older Northwood CPU's used less power btw.
Link to Asus P4SGX-MX downloads HERE for reference.
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
