Question about Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft. Conquest Side-By-Side Refrigerator w/ In-Door-Ice Ice Dispensi...
Ice maker has stopped working in my Whirlpool Gold sise by side. Water line is still connected. What is the problem? Is there anything I can do to trouble shoot it before calling a repair man or ordering a part?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Aug 28, 2010
Not making ice and not getting water to ice maker
Has the ice make r been working and then recently stopped?
Is there a filter in line with the ice maker?
Is there a shutoff on the water line feeding the ice maker?
Aug 18, 2014 | Kitchen Appliances - Others
The water dispenser and the ice maker have stopped working on my Whirlpool Gold GS5SHA. I have cleaned and defrosted the ice maker. The lines look clear. Any suggestions? Thank you.
Hello Kent, with the work you were doing on your frig did you shut off the water valve and just forget to turn it back on. This is a very common problem. Check and see, GOOD LUCK.
Oct 11, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
We have a whirlpool gold conquest side by side refrigerator. Water dispenser works, ice does not. Stopped suddenly making any ice. How do we fix it? It's only 2 years old.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it's frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don't refill with water.
ICE MAKER NOT GETTING WATER
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 21, 2011 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not make ice
If you have water sitting in the trays and no action is happening, then i suggest replacing the ice maker complete as these spares are pricey and take a while to get to you , (In the hope that they are correct). On some units there is a small test button. If you have one, push or switch it to activate icemaker. Often this resetting brings the ice maker back on line.
May 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker stopped working
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Hi. I have a Whirlpool sise by side gold
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 30, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The water is not working
Put a space heater in front of the door for an hour. If that is not it check the solenoid valve for obstruction.
Mar 01, 2009 | Whirlpool GS6NBEXR Side by Side...
Icemaker not making ice
The same thing happened to my Whirlpool gold. Defrost it for 24 hours and the ice maker now works.
Apr 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
427 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
