Question about GN Netcom GN 9350 Wireless Headset
Hi, I just upgraded my operating system to Windows 7 and it does not recognize my GN 9350 headset anymore - any Idea, what i could do? is is listed as "Unspecified" Device ...
    Sniper:
  • 123 Answers
The headsets only work with the Windows 98 (SE), Windows 2000 and Windows XP operating systems.
Posted on Aug 27, 2010
How to make a GN 9350 unit work with Windows 7?
Skip dealing with it. You don't need the $110 BS "upgrade" as this is a driver issue. Jabra could very well have provided a downloadable and install-able driver for the GN 9350 that would work perfectly, and tell windows not to use the unsigned USB driver in the headset firmware.
Fortunately there is a quick-fix workaround... it is only a little bit of a pain (and proof that their $110 firmware upgrade is not necessary).
When you want to use the jabra with Win7:
1. Plug it into your computer via USB.
2. Go to your playback devices menu (right-click the speaker icon in the system-tray)
3. Set the GN 9350 as the default device for recording and playback.
(right-click, and test, should error (couln't play test tone)
4. unplug the power to the reciever/base.
5. wait 10 seconds.
6. plug it back in.
7. may need to set it as the default again, but you should be good for a while, just don't switch back and forth too much between computer and phone.
Oct 03, 2011 | GN Netcom GN 9350 Wireless Headset
Hi, I have a GN8120 USB and want to use it with Windows 7. With Windows Xp it was installed automatically. With Windows 7 I got an error during installation. Do you have a solution for that? Thanks Best...
To enable Windows 7 support for the GN8120 USB headset, you need to make sure it's it has Firmware Version 11.0 or newer. The version 11.0 firmware updater can be found at http://www.jabra.com/sites/Jabra/GNimages/Software updates/GN8120_Update_790.zip or http://headsetplus.com/PDF/GN8120_Update_790.zip. Other headset updates and more info can be found at http://headsetplus.com/faqdesk44/faqdesk_info.html. Note that the firmware update must be performed under Windows XP, not Windows 7.
May 20, 2011 | GN Netcom GN 8120 USB Headset
Does not work for phone.
remove the battery and put it back
Oct 29, 2009 | GN Netcom GN 9350 Wireless Headset
GN 9350 Headset won't charge, blue light remains off I tried the solution of placing the headset on the charging cradle, then pressing both phone/USB button simultaneously The headset light...
Unplug the unit, then take the ear piece and slide the battery off .... When you have the battery detached from the ear piece, wipe off the metal prongs, leave it off for a few minutes, then put back together. Make sure you plug the unit back in. It will take a couple hours for the unit to be charged. That should take care of the issue.
Jun 21, 2009 | GN Netcom GN 9350 Wireless Headset
Headset button will not lift receiver unless ringing
You should be able to press the button on the headset as many times as you like and the lifter will respond, whether the phone is ringing or not
Mar 24, 2009 | GN Netcom GN 9350 Wireless Headset
My Headset just stopped working on the gn9350 headset. The base is on but it does not seem to be charging and there is no light on the headset or in front on the charging station. Is there some way to...
Hi I was in a live session with you when you left. Apparently you have not paired the headset with the base. All you have to do is follow this procedure
Place the headset in the charging base->Press the base's pairing button->Both the telephone and USB buttons on the base until the headset's link indicator will light for 2 seconds indicating that the pairing is successful. It should probabl charge after this.
Let me know if you need more help.
Sai.
Mar 17, 2009 | GN Netcom GN 9350 Wireless Headset
GN 9350 Wireless Headset doesn't ring on the headset when phone rings
It only picks up certain digital rings. I changed the ringer on my phone and had the same problem. To fix it, I had to plug in the little microphone that plugs into the handset lifter and place the mic over the ringer speaker. Now it works fine.
Jul 11, 2008 | GN Netcom GN 9350 Wireless Headset
Pairing GN Netcom GN 6210 with my iphone
Press the talk button on the 6210 Device and hold it until you here (2) faint beeps. Walla! (poor design and documentation?)
Mar 08, 2008 | GN Netcom GN-6210 Consumer Headset
GN Netcom GN 9350 Wireless Headset Logo
336 people viewed this question
Top GN Netcom Radio Communications Experts
Tom Chichester
MrFixitSTTL
techmncpa
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
