Question about Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum
My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
    Sergeant:
  • 252 Answers
No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
Posted on Aug 27, 2010
Lg vacuum cleaner overheats and shuts off.what is a problem?
How to Fix Vacuum Cleaner
With the link that i have attached i sure do hope that you will solve your overheating problems and others just in case. There are diagrammatic instructions also. Hope the information is useful and helpful.
Sep 17, 2016 | LG Vacuums
Shuts off while vacuuming. Seems to be overheating, no smell though, and will turn back on after sitting for awhile.
Amy,
Check and make sure that all of your filters are clean. I forget exactly how many filters are on the DC24, but I know that there are at least two and it sounds like at least one of them may be clogged and not letting enough air to get through to keep the motor cool.
Jul 24, 2015 | Dyson DC24 Ball All-Floors Upright Vacuum...
Reset switch
There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Sep 05, 2013 | Eureka 4700A Maxima Bagless Upright Vacuum
Hoover Mach 5 turns off after 5 minutes of using. Can you advise the problem?
5 minutes everytime? If so, raise brush all the way, and vacuum next to nothing. in fact, tilt vac up so the brush touches nothing. wait 5 minutes. If it doesn't shut off, your brush is set too high. if it does, the motor is over heating. make sure bag is empty, no debris in brush, filters clean and make sure you're not plugged into an outlet that a breaker on the outlet can pop too.
Sep 28, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
My Hoover Windtunnel supreme shuts off when I'm vacuuming. The bag isn't full, so I know that isn't the issue. Any ideas?
Normally, if the unit shuts off by itself, it is overheating. There is a overheat protection device wired in to the cleaner. Check to assure there is airflow thru the cleaner, to the bag.
Oct 03, 2009 | Vacuums
Mach 6 shuts off
If the vac shuts off and then turns back on after waiting a while. could be a thermal fuse. it is in the motor compartment. recommend a pro shop service this issue.
Sep 27, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Vacuum cleaner shuts off after short use. What's the reason. Motor seems very hot.
Almost all vacuum cleaners have a thermal cut-out, which operates when the machine gets too hot. It resets automatically when it cools down. Overheating is almost always caused by a blockage. Either the filters need cleaning or changing, or there's an obstruction somewhere in the pipe-work. Make sure all the pipes are clear so there's good air flow and you should be back in business. If the problem persists there may be trouble with the motor itself, in which case you'll need professional help (or a new machine). Good luck!
Jul 17, 2009 | Bosch BUC11700UC Cyclone Jet Bagless...
Our Mach 5 turns off after running for about 5 minutes and smells hot!! Help!!! We have 3 kids and I need to Vacumn.
Hello:
Go here
Then find the clean filter section and clean all the filters especially the secondary filters. i think this will solve your problem.
Jul 07, 2009 | Hoover U5194-900 Mach5 Multi-Chamber...
Mach 5 hoover turns off
Just got a solution off another website. There is a pre motor filter about the dust collection container. I opened mine and it was very dirty. I washed the filter and you are supposed to let it dry out for 24 hours. Hopefully this will work. Another guy said it worked for him.
Dec 29, 2007 | Vacuums
Hoover U5194-900 Mach5 Multi-Chamber Cyclonic Vacuum Cleaner Bagless Vacuum Logo
147 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
