Question about Samsung PN63C7000 TV
How to get into the samsung pn63c7000 service menu
Screen replacement cost?
take it to a repair shop for a quote
May 14, 2016 | Samsung PN63C7000 63" 3D Plasma TV...
SAMSUNG PL43D490A1DXZX
junk it get a flatscreen
Apr 24, 2015 | Samsung Televison & Video
Solid red light, no power, clicking in back of tv
Try changing the input device to something you are sure, works such as a DVD player.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Samsung PN63C7000 TV
Hoe to enter mode service samsung clx3175n
Log into the service menu Samsung CLX-3175 without a numeric keypad similar tothe unit Samsung SCX-4623F/FN:
Consistent set of combinations of
"MENU" - "COPY ID" - "LEFT" - "RIGHT" - "MENU" - "BACK" . Samsung CLX-3175XX/X with a numpad press: Menu, #1934, Menu
The unit switches to English, if you installed any other.
In the menu appears TECH MODE.
In
Samsung CLX-3175 to enter the reset require a password 1934. The numbers by pressing "LEFT" - "RIGHT",
After each number press the "OK"
Good luck in the reset.
Have any questions, you here http://skit-ltd.narod.ru
Jul 10, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
PN63C7000 plasma turns on but shows no image.
HERE'S THE ANSWER TO YOUR PROBLEM:
There could be a problem with your aerial or set box if there is something wrong with your TV picture or sound. Don't forget that there may be work going on at your local transmitter, or some kind of local interference.
Here's what you've got to do: Check with the local neighbours or another TV connected to a different aerial in case you are not the only person's aerial affected.. If only your TV is affected, the problem is likely to be in your TV, set-top box or aerial. If other TVs are affected, it's more likely to be caused by work at your local transmitter, or possibly the weather.
Your problem is solved. Thanks.
Jul 04, 2011 | Samsung PN63C7000 TV
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Service menu help for Samsung TXT3093WH
Go to ur service menu.Picture go down to reset,changes all setting to factory setting.Will reset everythings.
Mar 28, 2010 | Samsung TX-T3093WH TV
Samsung LCD Tv
Try this:
Access menu service by press on your command, with your TV OFF:
INFO + MENU + MUTE + POWER ON
Then you should get access to Service Menu.
The last item says: RESET
This will do a reset to the TV.
Make no harm.
WARNING: If when on service menu you feel tempted to "screw" on anything FIRST take note on ALL you change! You can compromise the TV ...
Apr 13, 2008 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Samsung PN63C7000 TV Logo
149 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
