Question about Numatic HVR200P Bagged Canister Vacuum
Burning smell from motor - Numatic HVR200P Bagged Canister Vacuum
I have the same problem. Burning smell , smoke and loud noise!! Any ideas?
Thanks
Carli
Posted on Jun 27, 2012
  • Numatic Master
  • 43,501 Answers
Check your filter and also check that nothing got pulled into the motor...otherwise the motor is burning up and will need to be replaced... probably cheaper to replace the whole vacuum..
heatman101
Posted on Aug 27, 2010
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
Hello can you help me please? I have a Kirby G4 vacuum cleaner, It did work ok until it started to give off burning smell and lots of sparks from the brushes. I have changed these brushes, the motor still...
Some debris, even sand or dirt, probably got into the motor, causing damage to the armature. If this is the case, you will need to replace the motor. The burning smell from the motor is generally a sure sign of a bad motor.
Jan 02, 2011 | Kirby G4 Bagged Upright Vacuum
Work well but smell like a burning belt
If it smells like burning rubber, the belt is probably worn and slipping. If it's another burning smell, your motor windings are probably shorting and will burn out soon
Oct 12, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum smells like something is burning
Ok...Check the brush roll is free not sticky..Next is the belt okay, not jamming on the brush roll making the burning smell...You could take off the roll and run motor on its own ..finding out if its the motor..
Apr 13, 2010 | Bissell Healthy Home HEPA Bagless Upright...
My vacuum cleaner is giving off a burning smell.
if its a rubber burning smell check the belt and the brushroll. if its an electrical burning smell then dont use it. the motor is overheating and will eventually get hot enough to catch fire.
Jan 02, 2010 | Vacuums
The motor makes a weird sound and starts to heat and smell like something is burning
If the motor sounds scratchy and is making a burning smell, or sparking you will need to replace the motor or the entire vac. Carbon brushes will rarely fix this as it is a high RPM motor
Sep 04, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning smell and smoke
When you turn it on....is the belt turning the brushes? Something may be caught causing the brushes to stick and the belt to just grind the brush assembly.
Jan 03, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Burning smell
Hi. What does the burning smell of? Is it 'rubbery', or is it acrid and 'chemically'?! The most common item to 'burn' is the belt which drives the rotating brush at the front. Does your cleaner have a belt? This would give a burning rubber smell. The instructions should explain how to change the belt - have a close look and see if the belt has been slipping on the motor spindle. If it has, then it'll probably be worn at this point and should be replaced. A common cause of this happening is the brush bar getting caught in something - edge or rug, etc - and being forced to a standstill. If the smell is more 'acrid', it could be a problem with the motor. This is a repair service job.
Sep 22, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
Numatic HVR200P Bagged Canister Vacuum Logo
486 people viewed this question
Top Numatic Vacuums Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
