Question about iRiver Spinn MP3 Player
My Iriver got wiped and now I cannot get the Root Menu to appear to select music.
    Problem Solver:
  • 10 Answers
U must have the music browse type on file tree go 2 set-advanced-music browse type-select Database
Posted on Oct 15, 2010
I can not upload song in my e100.......... explain me all process of upload song in my ipod & not open in my computer.....
The iRiver E100 uses iRiver Plus 3 to manage music, pictures, and more. iRiver Plus 3 can be downloaded for free here:
http://local.iriver.com/mas/download/downloadView.asp?selectPart=cateCode&findWord=01&sno=852&page=1&cateCode=01
  1. Insert the installation CD into your PC to display the installation process screen.
  2. Select iriver plus 3 and click the Install button.
  3. Complete the installation process by following the on-screen instructions.
  4. Turn on the iRiver E100, and then plug it in to the computer using the USB cable.
  5. Open iRiver Plus 3.
  6. Select the desired files / folders in your PC and drag & drop Music, pictures, etc. to the drive which appears as the product.
If you would like, there is a manual available here:
http://211.39.137.201//download.asp?filename=2008111114270150302.zip&filepath=/file/Down/
Jan 23, 2011 | iRiver E150 (4 GB) MP3 Player
IRiver E150 Shuffle
Starting from the main menu.
Select Music.
In Music mode: Press and hold the > button to view the Options screen.
Select Play Mode.
Under Play Mode: select Shuffle or Shuffle + Repeat.
You can also look this up in the E150 manual. Download the English.zip file from next page:
http://www.iriverinc.com/lounge/loungeView.asp?selectPart=03&findWord=&sno=985&page=1&cateCode=03
Unzip the zip file, with WinZip or WinRar, to view the manual in pdf format, that can be opened with Adobe Reader.
Jul 24, 2010 | iRiver E150 (4 GB) MP3 Player
Charging the battery on iriver E100
Yes, you use a USB cable to charge it from your PC.
Jun 18, 2009 | iRiver E100 Digital Media Player
System files missing
I fixed this problem for my mate, here's what I did:
1) plugged in H10 to pc that didn't have any iriver software on it
a) I've read if you press the "o" button on the iRiver H10 when connecting it will just connect as a usb mass storage device
2) the H10 now appears as a mass storage device
3) right click on the drive, and select format ( I choose quick format)
4) install the iRiverFirmware updater from http://iriveramerica.com/support/mtpupdate/
5) when you run the updater, it found the H10, then asked if the device was from USA or Europe, mine was from Europe
6) It stated that the iRiver firmware was v0.0, and would install v2.51 (I've seen v2.53 available on the european iriver website but could not download it).
7) proceed with installing the updated firmware
8) on the last screen it says, unplug to complete firmware update - NOTE press Finish first before unplugging
9) switching on the iRiver it 'rebooted' a few times and then when the menu appeared, I connected to the pc and just dropped some mp3 files into the music directory and all was okay.
hope this helps.
Here is for the Iriver H10 software:
http://iriverinc.com/support/hd/h10_5-6gb.aspx
Apr 13, 2009 | iRiver H10 MP3 Player
Files in Iriver H10 not appearing in music.
try this...
connect your h10 to the pc using the ums trick with the usb connection..
For 20 GB MTP Models
  • Make sure your H10 is turned off and disconnected from the computer.
  • Poke the "reset" button with a paperclip.
  • Turn on the hold switch (so that you don't accidentally turn the H10 on all the way).
  • Plug the H10 into your computer.
  • Turn on the H10 while holding the "O" button.
  • You will see the message "Emergency Connection" if you have done everything correctly. You can now let go of the "O" button.
download and run EASYh10 software (free playlist maker). It will scan the files in your music folder and build/save a playlist to your h10.
disconnect player and give it a try...
Mar 13, 2009 | iRiver H10 MP3 Player
Iriver says ''Check HDD Connection'' at initial boot up--
if you know some one with the same iriver...you can copy thier software (not music) onto you pc / laptop....disconnect & plug your iriver up...now you can format your iriver..copy the software onto it...its like starting fresh now.......but if no one is around w/ an iriver..you will have just purchase another one ...(if purchase hard drive you will still need the software)...
http://shop.ebay.com/items/?_nkw=TOSHIBA+%28hard+drive%29+1.8&_sacat=0&_trksid=p3286.m270.l1313&_odkw=TOSHIBA+MK3006GAL+30GB&_osacat=0
Nov 17, 2008 | iRiver H320 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Iriver h10 system initializing screen
The only thing I could do was completely delete the data and download everything all over again. I did this using the iRiver Firmware. For now I know no other way to get past this problem.
Aug 17, 2007 | iRiver H10 MP3 Player
Silly Question, Please Answer..
Yes, I have one of these as well... mine's not able to read the file types I stupidly loaded on it, but I know how it works. The way to get to the selection menu is to hold down the record button (has a single red dot on it) and the options come up, then you use the joystick to move sideways to the item you want and push the play/pause button to select what you want (in your case mp3)
May 14, 2007 | iRiver iFP-390T MP3 Player
iRiver Spinn MP3 Player Logo
61 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
