Question about Linksys Computers & Internet
I wanna to setup my wireless - Linksys Computers & Internet
    President:
  • 2,571 Answers
I wanna protect my connection from outside users i dont know how to protect it !! please help me out!
You listed your problem ubder: modems. A modem you do not need to protect further. You can only use the connection by hooking up a cable to it. If you have a wireless router connected to your modem that should be secured. You do this by entering a security code in the setup of the router. just enter the router's IP address in your web browser, log in to it,go to the security tab under wireless setup and enter a security code. (write it down because you will need it to connect wireless). You can not connect to it without this code. This way your wireless connection is secured and can not be used by outsiders.
Feb 10, 2011 | Computers & Internet
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Error 202 in setup wizard of linksys wusb54gc usb wireless adapter
it's not 1998 anymore, stop using windoze, or at least proprietary windows wizards.
try unix, mac os X. unix was the beginning of computer control and RTOS, and still is the best.
RTOS is real-time Operating System
or linux, however ubuntu kinda sux.
SUSe is about the best linux.
{it was used to make Android for google.
and if u don't wanna pay for os, and don't use torrents, or p2p, use openSuse. free download and use.
checkout opensuse.net or something like that.
d.pariah
Dec 30, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Hi , i just wanna know how do install my dynex dx-wgdtc without the installation cd from dynex , anyone can help me ????
The manual, drivers, setup, and wizard for this device can be obtained from
http://tinyurl.com/yhtbz7p
Nov 18, 2009 | Computers & Internet
NetGear NETGEAR WNDR3300 RangeMax Dual Band router
The Netgear wireless router wireless settings need to be configured and the the wireless card in the computer and XBox needs to be configured with the Netgear wireless settings.
Follow these steps. : -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router.
Oct 11, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Connecting 2 wireless routers
As a wi-fi technician, it is not recommended to extend the wireless signal using another wireless router. Having 2 wireless routers will just cause conflict to your wireless network. If you still have time, please replace the router with a Wireless Access Point (WAP54G). WAP is easy to setup. Just plug it to one of the ethernet port on the back of your router and run the setup CD that came with it, that's it. It'll extend your signal.
If your main concern is just extending your wireless signal to another far place outside your house, Wireless Range Expander (WRE54G) can also be used. It is a similar device like an Access Point but its signal extending capability is more powerful than Access Point. Its also easy to setup, just the setup CD that came with it.
You can also contact the Linksys toll free tech support # at 1800-3267114 if you wanna resolve the issue over the phone. Hope that helps.
-Regards
Oct 14, 2008 | Linksys Wireless-G WRT54G Router
Need to turn on the wireless capabilities
1.Go under the start menu. 2. Go to where it says connect to. 3. Then go to show all connections. 4. Click on which connection that you wanna use and either repair or fix the problem. 5. You can also just run the setup a new connection.
Jul 27, 2008 | Acer Computers & Internet
Computers & Internet Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
