Question about CSi Speco Televison & Video
My daycare says that they have SpecoRemote set up for parents to view the cameras from home. No one knows how it works, and the instructions for use do not seem to have enough information. When I ping their ip address, it says that the request timed out. When I type in their ip address in my browser, it says that a remote firewall is blocking the connection. Can you provide any assistance to find out what may be causing this problem?
  • CSi Speco Master
  • 3,187 Answers
To use an systerm remote cameras you need a provider, web cams can be on a ip address but to secure them so only allocated uses use them there is a user name and password. this is setup when the ip address is setup. like this system, Configure Swann Wireless IP Network Camera with CameraFTP Service for... there are meany systems but they should tell you the one to use this may help you understand. my own setup works from any device as lone as you know the password not the ip address as the software all read knows the address. and is cloud base so can use the cloud to watch pre recorded items up to 30 days ago . hope this information help you.
Posted on Jul 01, 2017
2 Suggested Answers
  • 902 Answers
SOURCE: Request specific code or codes
Found some quick solutions including the manual for you
first here is the link for hte code list and manual http://www.rcaaudiovideo.com/remotes/2-3-devices/?sku=RCRN03BR
which i got from various sites after researching your problem for about 30 minutes please let me know if this works i hope i helped i tried really hard
if that doesnt work try these methods PLEASE LET ME KNOW IF I HELPED
for this first method you need the direct code which is 04
  1. Manually turn on the component you want the remote to control.
  2. Locate the Brand Codes in the Code Lists.
  3. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  4. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  5. After holding both keys down for three seconds, the illuminated ON·OFF key turns back on.
  6. Release both keys. The illuminated ON·OFF key remains on.
  7. Refer to the Brand Codes. Press and release the appropriate brand code key (Numbers 0-9), using the number keys. The illuminated ON·OFF key blinks once.
    • Note: If you do not press a valid Brand Code Search key, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  8. Press and release the ON·OFF key repeatedly until your component turns off. Each time you press the ON·OFF key, the illuminated ON·OFF key blinks, and the next code is sent. The Brand Code Search begins with the first code in the chosen brand list for that component and cycles through all the codes for that brand. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON·OFF key blinks four times and turns off, all codes in the chosen brand list have been searched and another programming method should be tried. The Brand Code Search mode is exited.)
  9. Once you have found the correct code, save that code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work, program the remote with a different programming method.
if not try this for auto code search
STEP :
  2. Press and hold the component key you wish to program. The illuminated ON·OFF key turns on and remains on.
  3. While holding the component key down, press and hold the ON·OFF key. The illuminated ON·OFF key turns off.
  4. After holding down both keys for three seconds, the illuminated ON·OFF key turns back on.
  5. Release both keys. The illuminated ON·OFF key remains on.
  6. Note: If you press an invalid key during Auto Code Search, the illuminated ON·OFF key blinks four times and turns off. The last programmed code under that component key is retained.
  7. Press and release the PLAY key, then wait five seconds to see if your component turns off. If your component does not respond, continue to press the PLAY key every five seconds until your component turns off. Each time you press the PLAY key, the illuminated ON·OFF key blinks ten times and a block
    of 10 codes is sent to your component. This process continues until all of the codes in the Code Lists have been searched. (If your component has not turned off after all codes have been searched, the illuminated ON·OFF key blinks four times and turns off. The Auto Code Search Entry method is exited.)
  8. When your component turns off, you know the correct code is in the last block of 10 codes sent. Press and release the REVERSE key. Wait two seconds to see if your component turns on again. If your component does not respond, continue to press the REVERSE key every two seconds until your component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE key is pressed, the illuminated ON·OFF key blinks.
    • Note: If you accidentally press the REVERSE key after your component responds, press and release the FORWARD key. Then, wait two seconds to see if your component turns off again.
  9. Once your component turns on, you have found the correct code. Save the new code by pressing and releasing the STOP key. The illuminated ON·OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
  10. When you press the STOP key, the code is stored.
Posted on Mar 16, 2011
Is it normal for a child to cry a lot when they go to daycare?
There is no reason that any parent should have a "suck it up studies are important" attitude when it comes to preschool. While preschool is about learning, it is also about making friends, dealing with separation, and learning how to attend school...something that kids don't learn how to do without practice.
When a child cries at preschool it can mean any number of things:
The child is spoiled and is constantly held by mom, dad, or another family member at home and cannot stand not being held at school
The child does not feel comfortable in the classroom whether because they are uncertain about the teacher, their peers, or the separation from their parents
The child thinks that their parents are abandoning them and will not come back for them, because this is very common thinking for this age group
The child thinks that something is going to happen to them that is bad if mom and/or dad leave because they cannot fathom in their brain dealing with anything without their parents around
When a child cries at preschool, the worst thing that a parent can do is to hang around and cuddle and hold the child. This teaches the child that they can get mom or dad to stay just by crying and every time this scenario is played out, it makes the next separation that much harder. Allowing the child to bring a familiar item from home such as a favorite book, favorite stuffed animal to hold during nap time, or putting a photo of their family in their backpack or lunchbox can help a child get through the day.
In other cases, sometimes when a child cries at preschool it can be a sign of something more serious, like abuse from one of the adults in the preschool. It's important as a parent to volunteer in your child's class from time to time, observe your child's teacher, and report anything strange, unusual, or that makes you uncomfortable immediately. Additionally, you can ask your child about their day at school. Ask them questions that require more than a yes or no answer such as "What did you do at school today" vs "Did you have fun at school today". Ask your child questions like "What didn't you like about school today". Children are brutally honest and if something is going on at your child's school, they are bound to open up about it to you if you know the right questions to ask.
Jan 04, 2017 | Preschool
I own a dance studio? How do parents watch their ballerina from a TV in the stents Louge?
A couple of options depending on your situation. If the lounge has a smartTV, one that can access the Internet, your simplest would be to purchase a wireless camera, D-Link is one brand and under $100 at Staples, Costco, Bedt Buy, etc. You would also need access to wireless internet in your studio. You set up the camera with name and password and set up the free hosting via a D-Link website. Once the camera is configured, you log onto the website via the smartTV, put in the password and you can watch the camera feed. This can be set up so parents could even watch from home or Grandma from the care home. All anyone needs is a computer or tablet to access the Internet.
Other options include a wired camera where u run wires from camera to ,TV. all depends on your requirements and DIY capabilities.
Jan 25, 2015 | Home Security
Nintendo error code
There has been a Parental Block placed on the viewing of Internet Videos. you will need the parent whom set-up the restrictions to make a change with their PIN in order to proceed.
Jun 29, 2014 | Video Game Consoles & Games
Remove child lock
See the instructions beginning on page 40 of this manual: http://service.us.panasonic.com/OPERMANPDF/KXTG7841-MUL.PDF
Jul 17, 2013 | RCA F32650 32" TV
Resetting parental controls on my RCA projection TV
From the main menu choose "Parental Controls;" it's option six.
Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
Lock the controls to activate the changes using item six on the "Parental Controls" menu.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or make a search by typing in the brand name of the device in the "Search Box", at the top right of the display window
Dec 04, 2012 | RCA Televison & Video
How to unlock childs security?
RCA TVs come with a child lock capability called V-Chip. It's a parental control system which allows you to block programs and films by content, age-based ratings and the ratings which come with the movies. The parental control is a code, sent by the broadcaster to your television. The V-Chip will not work if the broadcaster doesn't send the control, or if the parental controls are switched off or unlocked. The controls are set up in the TV's main menu. The default is off.
Instructions
Jun 28, 2012 | Sansui DTV3200 32" TV
How To Remove A Parental Lock Without The Remote Control?
That is called Hotel Mode. Look in your instructions for help.
Enter the service menu and select Hotel Mode to switch it on or off.
Apr 15, 2017 | Philips Magnavox MT2501C 25" TV
Activex blocking usage of speco remote
Open the "internet options" menu through tools. Click on "security" tab. Then select the "internet" and click on custom level. Here, navigate to the "Activex controls and plug-ins" section. Change "Download Unsigned ActiveX Controls" to "prompt" and do the same for the setting directly below that. This should clear up your problem
Nov 03, 2008 | CSi Speco DVR-PC8 Video Recorder
we have parental lock on our tv.....the screen is blue with a lock in the lower left corner,we can't get it of with our 3in 1 remote....a tv. repair man said we needed the original remote....can you help with this problem
smiller1517@yahoo.ca
Tks.
Jun 02, 2008 | Durabrand DWT1905 TV
Televison & Video Logo
46 people viewed this question
Top CSi Speco Televison & Video Experts
 Russ Hill
Russ Hill
Are you a CSi Speco Televison and Video Expert? Answer questions, earn points and help others
