How to use creda 79143,night storage heater.cant find any info on web
5 Suggested Answers
hotuna
  • 288 Answers
SOURCE: Storage Heater
You will need a volt/ohm meter. remove the element or at least the wires on each end. set the meter to ohms, touch each lead from the meter to the opposing ends of the element. The meter should have some type of resistance. If it shows open or the needle doesn't move (on the older non digital type) then the element is bad.
Posted on Jan 05, 2008
SOURCE: operating instructions for creda storage heaters
Suspect a fuse blown. These are normally easily accessible at the top of the heater, once you have ISOLATED the supply and removed the cover, very carefully. (MAY be asbestos inside, if they are old heaters...)
Posted on Aug 18, 2008
  • 38 Answers
SOURCE: i have a creda storage heater 79153, i turned it
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Posted on Nov 04, 2009
jsrock516
  • 5911 Answers
SOURCE: creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Posted on Nov 15, 2011
Creda 79141c
Turn it off and have it checked by a registered electritan. Please DO NOT use it until you have!
Jan 28, 2014 | Heating & Cooling
Creda storage heater manual
Nov 15, 2011 | Heating & Cooling
I have a 12yr old Creda storage heater upstairs and a petroleum type smell is coming from it. Never happened before. Do you know what I should do?
Sounds like the unit may need cleaning or there is something else in the area that's generating the odor and the heater is picking it up and making it worse.
Jan 19, 2011 | Heating & Cooling
Hi, Last night none of the Dimplex storage heaters in my home came on. I checked the fuse box and nothing has been trippped. They were working fine the night before and I cant think of any reason why they...
It may be that the off peak to your house has failed to switch on, possibly due to the off peak time switch in your meter cupboard not working, I suggest you contact your local electricity board and ask them to check your off peak supply
Dec 15, 2009 | Dimplex DS5603 Heater
I have a creda storage heater 79153, i turned it on on sunday night monday morning it was still cold , i changed the fuse at the wall still nothing, the only part that works is the convector heater at the...
Oct 21, 2009 | Heating & Cooling
Over riding switch
You could have a defective thermostat causing the limit control to trip off. Here is the manual!
http://www.insinkerator.com/pdf/POU_ICU.pdf
Copy and paste to your address bar.
Jan 20, 2009 | Emerson InSinkErator W-152 Electric...
Storage Heater
Jan 04, 2008 | Heating & Cooling
Operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Jan 03, 2008 | Heating & Cooling
Instruction Book Needed
Go here: http://www.creda.com/macro/header.d2w/HomeStart
Dec 28, 2007 | Heating & Cooling
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
