Question about GE Energy Star WCVH6260F Front Load Washer
Washer comes on but won't wash. counts down but starts at 5.1
  • GE Master
  • 17,129 Answers
Is the flow of water too low? or is the water level sensor faulty?
Might have tto check the progress of the timer before it can contact the motor to run.
So is it possible that the sensor is not detecting for the program to go forward. Please check this out.
Posted on Aug 27, 2010
I have a kenmore front load washing machine that water shuts off after 5 seconds. Timer continues to count down but nothing happens in the machine. Timer also takes about 3x longer to get to zero.
Troubleshooting Appliances: Washing Machine and Dryer ...
www.realestate.com > Realestate.com Blog > Articles
Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
Oct 19, 2015 | Kenmore Washing Machines
What is the sequence to get code to find out washer malfunction?
Press both the start and pause buttons together and count the beeps. Then the light above the start button will flash so count those. Example is 5 beeps and 9 flashes means error code E 5-9
Jun 29, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
Hello, I have a whirlpool duet wfw94hexlo washer. got an error code, drain filter assy., cleaned it put it together. when you go to start machine all seems normal. you push start, door locks, light comes...
Great! you have the MCU (motor control unit) need to replace. Removing the rear panel so you are able to see the motor and MCU. Replacement is easy, almost no screw on the board.
Oct 22, 2013 | Whirlpool WFW94HEX Washer
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
Jun 28, 2013 | Washing Machines
Washer start to run water the it just stop
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Feb 20, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Timer dosent count down
HI, this is a simple fix here, you will need to replace the timer/control module. this will fix this issue. this specific device is ruined and, unable to initiate the wash cycle correctly due to circuit damage.
May 18, 2009 | Whirlpool Calypso GVM9959K Top Load Washer
F code
Machine off press and hold for a count of 5 the spin button and release for 5 until 88 appears. If a F error comes up write back for a solution
Oct 13, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Bosch SHU5318: Water wont start washing
if it hums when you are in the wash phase then something is jamming the wash impeller like broken glass tooth pick found a necklace in one one time i think replacing the control board fixed the other problems on most washers the drain pump is separate from the wash motor haven't worked on bosch so not sure take off the lower spray arm and go down till you get to the impeller then do what you have to do clear it or replace wash motor
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
Oct 10, 2007 | Frigidaire GLTF2940ES Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
27 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
