I have a problem with my computer monitor, the color turn to bluish(blue) color. what can I do to solve this problem.
    President:
  • 2,571 Answers
If this is and older CRT monitor, and not a modern TFT monitor, the guns are faulty, this has happened to a few on my old monitors, always turn blue.
Time for a new monitor, it would cost the price of a new monitor to fix it.
Posted on Aug 27, 2010
Hi, I have a samsung samtron 55V 15 inch monitor. The problem is it is not displaying the actual colors. The red color appears as a greenish/bluish shade. Ex: The Windows Start button is showing as light...
You have to check for dry soldering in the base board of you mointor. The base board is on which is attached to the picture tube neck. In most cases there will be dry soldering in the pins of cathode diver ic in that base board. It will be difficult find out which pin have the dry soldering. Do on thing resolder all the pins of that ic. This ic cotrols the three cathodes of picture tube (red, blue, and geen) is any one did not get the correct drive that color will fail to display. In your case the red cathode is not getting the drive voltage. Thats why it shows only gree and blue. This is a reular complait for crt monitors.
ok
Jul 17, 2011 | SAMTRON 55V 15" CRT Monitor
Color is off....keeps turning bluish. Greens appear yellow
Funny colors is most often caused by a loose cable.
make sure BOTH ends of the cable are secured by tightening down on the thumb screws
Feb 01, 2011 | MegaVision MV220 Monitor
When I turned on my computer the monitor colors looked normal - after about 1/2 hour the overall color became bluish and when I tried to change the appearance of the display, my only options are blue...
Try a different "data" cable between the monitor and your computer.
Try connecting your monitor to a different computer, to see if the monitor has the same problem.
Try connecting a different monitor to your computer, to see if your computer's video-card is the source of the problem.
Jun 11, 2010 | Gateway FPD2275W LCD Monitor
Monitor is not in normal color
Check to ensure the plug is all the way plugged into the back of the machine. Tighten the thumb screws and this should fix the problem.
Jan 21, 2009 | Computers & Internet
Emachine monitor lose color.
HI Bernard,
This sounds to me like the video lead is loose. Could you please try the video lead each end and tighten the locking screws if possible.
Regards
Nick
Oct 29, 2008 | E-Machines eMachines Monitor E15T4
Desktop screen display goes blue
can u boot into the system?if not it can be solved if yes then there is a problem with ur monitor
if u cannot boot intoo the system load default or system restor tht u do ,......savio k frm mumbai savio_k20@yahoo.com let me know if u solved it
cheers
Jul 05, 2008 | HP D2835 17 in. CRT Monitor
Blue tint on monitor
If you mean you can still see your screen and everything on it, but everything is very blue, then check your video cable from the PC to the monitor.
It will have a broken wire inside and is a common problem. Just wiggle it around in a circle and it should come good. Hold it in that position with something until you can replace the cable.
Apr 18, 2008 | E-Machines eMachines Monitor E15T4
Monitor color problem
there should be color adjustments in your menu.
also i don't think its the cable if its blue, cuz, if you was miss just blue it would not be blue. and if you had red and green it would not be blue. some video cards have settings to adjust the color in the driver settings or display properties. good luck.
Apr 10, 2008 | Gateway FPD1975W 19" LCD Monitor
Bluish screen
Before spending money on a new video card you might not need. Check all your connections. I have a monitor built into a Radio station announcer's desk and it goes blue at switch on. All I did was reposition the input cable and problem solved. It was caused by a fractured wire or two in the output cable and moving it made them make contact again. It's worked for 4 years now, if it really dies then I'll have to pull it out and replace the whole cable. Check that all your inputs and outputs are firmly plugged in and any securing screws are finger tight. But remember the old tech's saying "If it's gonna go wrong it'll usually be in the first few weeks" BMW
May 26, 2006 | Acer AL1916B 19" LCD Monitor
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
