Question about Nokia HS-23 Headset
My HS-23 stereo headset had accidentally got plucked off and totally disconnected from the soldering of the mobile section. I checked all the wires in the headset using continuity tester and I found all were working. I just need to solder the wires that has been plucked off from the mic switch but the problem is that I am unable to understand which color wire should be soldered to which point. Could you please help me out which color wire should be connected to which terminal in the mic switch case.
2 Suggested Answers
SOURCE: need help for hs-23 headset repair
In this middle section, the wires are as follows: MIC+: Yellow MIC-: Black L+: Blue L-: Copper/Grey Stripe? R+: Copper R-: Copper/Grey Stripe? (same as L-, they should be interchangeable...) Sirial?: Yellow/Orange Stripe Uout: Red GND: Green Hope this helps!
Posted on Jun 08, 2008
I accidentally stepped on the cord that goes Into the headset and it pulled on the cord and It just stopped working, please help me.
All that needs to be done is to check the continuity of the cord and fix it back to the section of the jack or the headset.
Most possible the wire would have stretched and so you will need a stereo cable that needs to be soldered into the jack and headset ,only if continuity is lost in the stretched wire .
Sep 27, 2010 | Voyetra Turtle Beach Ear Force X3 Wireless...
Can you adjust volume using nokia hs23-headset?
At the side of the headset microphone are 3 buttons, the center is called PTT and the other two adjust the volume.
Jan 12, 2010 | Nokia HS-23 Headset
SKullcandy lowrider headphones cut wire
Take it to someone familiar with electronics. SOME of the wire types are very hard to solder. These are kind of "tinsel" wires for flexibility.
They likely can be repaired and some shrinkfit tubing put over the splices.
Jan 06, 2010 | Skull Candy KB Electronics Skullcandy (...
HS-23 problem disconnected
Assuming that the joint which connects the neck strap has been damaged ( see below image )
, I advice you fix the loosed or broken joint back in its proper place permanently by using fevi kwik or some other fast bonding adhesive, but the only problem which will remain is that each time you have to use the headset you will have to wear it through your head andremove it the same way.
Apr 19, 2008 | Nokia HS-23 Headset
Please help me with a diagram for hs-23 plug connections...
http://free-zg.htnet.hr/GoranJurkovic/nokia/
http://cellphones.hackaday.com/2005/08/16/how-to-make-a-nokia-pop-port-to-female-mini-jack-with-volume/
Dec 03, 2007 | Nokia HS-23 Headset
Headset not Supported
Nokia HS-3 is a stereo headset.
Your phone does not support stereo.
So Use mono Headsets like HS-5.
Nokia 9300 is a stereo supported phone and hence works with the headset fine.
Dec 01, 2007 | Nokia 7610
HS-23 Not Being Recognized by Phone
Rub the pins of your headset, and your phone with some tissue paper or something like that.
You might use some cleansining agent like alcohol.
Switch off your phone while doing that.
I too encounter such problems.
Dec 01, 2007 | Nokia HS-23 Headset
HS-23 Nokia Headset
hey kev.. all i can ask you is ... the following 1) open the ear piece of the non working .. then take a multimeter (keep meter in resistance mode) and check the resitance if its good it will show you.. apx 32 0hm and if its showing you 0 or .1 or below 16 ohms.. 2) after you disconnect the speaker.. the broken one that is... chek the cable connectivity.. or rather continuity.. for this keep the meter in continuity mode the pervious resistance mode.. then take one wire and connect one prob from meter to it.. and take the other prob and connect ti too the pins of the cnnector.. ( here is there are 4 pins dedicated to the ear phone.. 2 for each.. nd they are towards the end sid.. just below the # key.. frm # key the last 4 pins connectors are for audio.. ) check the.. pins on the cord connector not the phone.. i hope you can find what wrong with your... head set now.. and yeah if the speaker is out jsut replace both the ear piece with sony or aiwa earphones.. it wil work best if your cable is gone then all the best buy a new one tc aditya
Aug 04, 2007 | Nokia HS-23 Headset
Nokia HS-23 Headset Logo
60 people viewed this question
Top Nokia Radio Communications Experts
shaun taylor
Computer Repairing
Computer Repairing
Are you a Nokia Radio Communication Expert? Answer questions, earn points and help others
