Question about Sony Grand WEGA KF60XBR800 60" Rear Projection Television
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute or two then shut down. I read that a high current draw from the lamp can cause the set to turn off, I do not know if this will work because of the protection circuit but was thinking if the lamp was removed will the set turn on? If so you would still hear the audio and if it did not shut down that would indicate that there was a good chance replacing the lamp would solve the problem. Does anyone know if the set will be damaged by running it without the lamp or for that matter will it even turn on?
  • Frank Monaco May 06, 2008
    The lamp is a XL-2000U but I will give it a try.
  • Frank Monaco May 07, 2008
    Thank You
  • Sony Master
  • 5,138 Answers
Your lamp needs to be replaced XL2200 if this is your lamp number they are not holding up.
Posted on May 06, 2008
  • ladywinn
    ladywinn May 07, 2008
    Set will not turn on without lamp.safty devices.Order new lamp and your set should be good to go.
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Tv remains on for about 20 minutes then shuts off by itself and won't come back on. please help
does the power indicator blink when the set shuts down? If so thats an error code let me know the number of blinks and I will assist with the reason why the set is shutting down.
Jan 20, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Stalling coming on
LG's are known for having bad capacitors in the power supply. These components will cause all kinds of problems like not turning on, no backlight or no video and are known to do this after the TV has been off for a few hours or days. You will need service on this TV.
Jun 26, 2009 | LG 42LC2D 42 in. LCD HDTV
TV turns off after two minutes. Power light blinks for a few minutes then TV comes back on. Turning the power off after the set shuts itself off will cause the power light to blink five times for a minute...
5 blink indicates - AKB circuit (AKB), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. Also unit be in IK blanking, try turning up screen slightly.
Jan 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV won't turn on
There is a failure in the scan amplifiers, and or the power supply. This will require trouble shooting by an experienced TV tech who has access to the service manuals and know the set.
There are many components in the set that can cause this type of failure.
Did you not take an extended warranty???
This type of repair is not low in cost to have done.
Jerry G.
Jun 05, 2008 | Mitsubishi WD-62725 62" Rear Projection...
TV won't turn on
Ready? The solution is = Replace four capacitors inside DM module 1000mf / 25v high temp. For details.........Look @..
Oct 24, 2006 | Mitsubishi WS-55613 55" Rear Projection...
Sony Grand WEGA KF60XBR800 60" Rear Projection Television Logo
130 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
