Question about Samsung Televison & Video
What is the rate for an IC of samsung tv -tda9381ps/n3/n/1959
SOURCE: Half part is display
replace ic
Posted on Sep 29, 2008
  • 901 Answers
SOURCE: chaild lock use ic tda
You have to go through the MENU mode and clear it. If it is not clearing, you have to change the main IC.
24 CO16 is a programmable chip. You can not use it as it is. you have to program this. Better take help from the mfr service provider.
24 CO 16 series are eeprom and they never get corrupted! You have to check the main IC.
Posted on Aug 22, 2010
SOURCE: my LG TV Model 21FD2RG-AX
tv on to just off
Posted on May 09, 2011
srinibash_ka
  • 15 Answers
SOURCE: TDA9381PS/N2/3/0660 BASED SAMSUNG TV INSTANT GOES OFF WHEN POWER ON RASTER CAME AND TV TURN OFF WHAT THE POSSIBLE PROBLEMS SHOULD I CHECK?
This fault is in protection circuit.First check the 125V.D.C at sm out voltage.then eprom I.C.(memory) & Set the parameter by opening service mode Stanby>Display>Menu>Mute>Power on if require.
Posted on Jan 12, 2012
Testimonial: "thanks Srinibash Kar sir ..."
gopakumarg43
  • 75178 Answers
SOURCE: lg 21" flat tv using ic tda9381ps n3 /3/1959.The display is white with retrace lines &picture
Check all the voltages at its video output card [CRT base PCB] If all are found OK, check and replace the chroma IC. The most probable cause is defective IC itself. Check its heating effect. Will overheat within minutes after the set is switched ON.
If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Posted on Aug 29, 2016
Samsung TV used tda9381ps/N3/3/1774ic nopicture nodisplay plainretrace line
High voltage is needed to power the screen. Check the high voltage circuit. Take off the rear panel. The high voltage is need where the 120 volts. There is a high voltage transformer and on the output the volts should equal at least 390 volt DC - check it at the capacitor. If not, check the capacitor. The one in the TV is 100 uf rated at 450 volts. I put in a 370 uf rated at 400 volts.
Jan 01, 2018 | Samsung Televison & Video
TDA9381PS/N3/3/1997 Samsung plano tv..my video input is not working plz help me out
Make sure your set to video on the screen if you are then change the main board and it should fix your issue
Oct 30, 2017 | Televison & Video
Sinck problem
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result might display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Aug 11, 2017 | Samsung Televison & Video
Lg 21" flat tv using ic tda9381ps n3 /3/1959.The display is white with retrace lines &picture
Aug 29, 2016 | LG Televison & Video
TDA9381PS/N2/3I1041 alernate ic name...?
To my knowledge there is not an alternate circuit. Take a closer look, the number you gave is for a vertical defliction IC.
Nov 12, 2014 | Samsung 24.8 Cu. Ft. Side-by-Side...
Jan 12, 2012 | Car Audio & Video
LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
Nov 12, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
