Question about Zanussi Washing Machines
Hi i have a zanussi zjd 12191 with a fault code E40 showing ? thanks
kjmac
  • 97 Answers
SOURCE: zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Posted on Nov 11, 2008
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
ginko
  • 19396 Answers
SOURCE: I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Posted on Oct 15, 2008
SOURCE: zanussi zjd1219
Hi
Machine is showing E40 ERROR
Posted on Nov 10, 2008
blueextc3221
  • 15935 Answers
SOURCE: error codes E40 andE70 showing on model zwf1640s(zanussi)
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame at approx 3 o clock pos,where the door striker pin goes through hole.
Held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
Check the Door Switch/interlock or the WIRING for failure in this case and repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
What does error E40 mean
Zanussi Washing Machine E40 Error Fault Code
Electrolux Time Manager How to Fix Error E40
E40 indicates a problem with the door lock circuit in the appliance.
It could be as simple as a faulty door lock or it can be a faulty main control board.
Jul 16, 2017 | Washing Machines
How to reset zanussi jetsystem programme function board with error E40
E40 is a door lock fault code, you need to replace the door lock,
you cannot reset the fault code, this happens automatically when the fault is rectified. nice easy job though.
Sep 30, 2016 | Zanussi Washing Machines
Power button seems to be broken
the trigger has been damage you have to replace it .if you want i can fix it im a technician
Jul 18, 2009 | Washing Machines
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi zwf1631w error code e40
hiya
hope this helps
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Zanussi zjd1219
Hi
Sep 07, 2008 | Zanussi ZJD1219 Front Load Washer / Dryer
Error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Feb 28, 2008 | Zanussi ZWD1470W Front Load Washer / Dryer
RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
Dec 11, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
221 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
