Question about Toshiba Office Equipment & Supplies
CALL FOR SERVICE C44 e-studio207 TOSIBA - Toshiba Office Equipment & Supplies
  • nirah Aug 28, 2010
    sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
  • Mohammad Shakeel Jan 17, 2012
    sir I have Toshiba 207 copier sir now write on screen call for C44 sir please solve this problem its very urgent please
Sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Posted on Aug 30, 2010
Please describe your CALL FOR SERVICE C44 e studio203 TOSIBA problem:
Posted on Apr 13, 2011
  • Toshiba Expert
  • 414 Answers
0 aur 8 ko ek saath daba kar machine on kare iske baad 400 type kare aur print key dabaye jo bhi figure aaye use 0 kar de aur enter key dabaye aur intrrupt daba kar machine off karke firse on kare machine se service call hat jayega
Posted on Aug 17, 2012
Hi have thoshiba e studio 200s i have problram with this printer i cant print or copy or fax massage on printer shaw front or back door open but i chicked that is all colsed pelase can you let me know how to resolbed this problem
Thanks
Posted on Dec 24, 2012
Toshiba estudio 181 error c44 how to solve
Here in this post I explain about a specific problem faced by Toshiba eStudio printer users. Toshiba eStudio series is high speed printer and mainly used in corporate offices. One day when you work all of a sudden you receive an error message from the printer and it shows C44 and now you can't print anymore. Frustrating isn't it?
Little bit facts about the C44 error, C44 simply means that the count of printer has gone above the limit and it needs service. But in most cases its false positive, means many reasons can bring up the issue. Some of them include over heat of printer parts, issue in settings, or any particular component failure but above all it occurs for some unknown reasons also and that's why you can use this to rectify the issue. The advantage of doing this is that if the issue do not solve up after doing this you can call you service engineers but if it gets solved it can save your money for calling the service engineers.
Solution:
  1. Switch off the printer first.
  2. Now Power the Printer by pressing 0 and 8 keys (keep pressing).
  3. Then a test mode comes up.
  4. Now Type 400.
  5. Press START (!)(You will get a counter and now you need to reset this).
  6. Type 0.
  7. Press Enter(start)
  8. Switch off the Printer now and restart and check again with first steps till typing 0 (You need not type 0).
  9. Now switch off the printer and on it normally.
  10. You should see printer working normally
This fix is applicable to all Toshiba eStudio printers.
Nov 03, 2017 | Toshiba Computers & Internet
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Jan 17, 2014 | Toshiba Office Equipment & Supplies
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jan 14, 2014 | Toshiba Office Equipment & Supplies
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Dec 31, 2013 | Toshiba estudio 255 Copier
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
Jul 08, 2012 | Toshiba E Studio 207
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
Sep 03, 2009 | Toshiba e-Studio 205 Copier
Ive just put in new ink now it says i need to service it prior to the new ink it was printing perfect is there an override for this my email is ssideburns@hotmail.com tanx
Sounds like your talking about a service timer reset, you should be able to find a solution on google, if you don't get anything please let me know.
Just so you know it's usually a whole sequence of pressing your paperfeed button.
May 27, 2009 | Epson Stylus C44 InkJet Printer
Call service c44
"c" "auto'-"c" "auto'
14 start
6 start
clear
Nov 24, 2008 | Toshiba e-STUDIO 120 Laser Printer
1,156 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
