Please i need to know the power IC for my goodmans GTVL32W26HDF tv . and please how do i replace it if it does not on .is
  • 901 Answers
Check the fuse first. Check the main DC supply diodes.
Posted on Aug 27, 2010
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Sdv594 will not turn on
your problem is in the secondary power supply ic 520 memory ic is bad try and get it repaired.but please be reminded that the ic is a surface mount.i would advise you buy a new dvd player but if you dont want to.. have a tech do your repair who can replace your ic.good luck
Feb 27, 2010 | Toshiba SD-V594 DVD Player / VCR Combo
Goodmans model gtvl32w26hdf. Switched itself off. have changed fuse, with not difference. blue standby light comes on, using remote press standby blue light goes off, screen remains black.
Good Day SIr, sound to me like your switching power supply is not working properly, there is an IC that controls the switching action of your power supply, this MAY be the reason why it stays off. locate the IC at the power supply section, replace it then test. There is also a possibility of open low value resistors near the switching transistor (very hard to locate). hope this helps.
Sep 23, 2009 | Televison & Video
Power stops only in the power unit
Replace the Power Supply, had that issue about a month ago and found one supplier of the ic I needed , that was in China, told the customer and she said scrap it and bought a brand name from us.
Aug 25, 2009 | Polaroid FLM-3201 Television
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Mod. # PLV16190 can you help me fiend the LP1619 main board ,PLV1619-02-01 , C33-PL1619w101, MP000806A thanks tec. H.A.O*Su.
What is wrong with your TV?Red standby light is lit,but the TV doesn't turn on?Open the back of the TV,and look at the can shaped items on the board that the power cord is hooked to,as well as the board that goes to the screen that lights up the bulbs.If any of them have the tops,or bottoms bulged out,they need to be replaced.This should get it working again.I hope this helps.Please let me know if you have any questions.Thank You very much!
Tyler
Sep 14, 2008 | TruTech PLV16320 Television
Piomeer 643hd5
no sounds like either the vertical output IC needs resoldering or maybe defective. vertical IC will make the tubes shutdown for safety while audio and Crt heaters will remain on. Try resoldering the IC if that doesnt help replace the vertical output IC its an inexpensive part. If you need more assistance please let me know
Apr 10, 2008 | Pioneer SD-643HD5 64" Rear Projection...
TV sound problem
first my brother you have an old set which needs to be service take out the circuit board clean it and do resoldering in the audio circuit.if that does not solve your problem then it is time to call the tech,it means that your audio ic needs to be replaced and the associated components you can also look on some dried up caps which could be a part of your problem.good luck.
Mar 27, 2007 | Goodmans W280NS Television
Cant See bottom half Of Screen On My TV
If your a technician i would tell ya to go into the set and change a couple of choice capacitors and possibly the vertical output IC.. if your not a tech then you cant service this set by your self as there are no serviceable parts inside the set so you should really take the set in and good Luck!
May 15, 2006 | Goodmans 255NS 25" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
