Question about HP Pavilion dv6000z Notebook
HP Pavillion dv6000 - dark screen, no power noise, but power lights are on
Our laptop was open/on and all the sudden, the fan sped up, then the screen went dark and there was no more noise. Power lights were still on, though. I forced it off. When I try turning it on, the power lights come on, but it doesn't make ANY noise (no fan, no power hum) and the screen stays dark.
Any ideas?
  • 2 more comments
  • Anonymous Dec 15, 2008
    dv6000 was sleeping after being away for the day. It wouldn't respond to mouse or keyboard to wake it up, so it was forced off. Now it turns on all lights but there is no sign of a fan or hard disk. Sometimes after the LEDs are glowing for a minute or two is cycles off and back on. No beeps, no display at all.
    DV6000 was in sleep after being away for the day, and it would not respond to keyboard or mouse. After being forced off, when it restarts it shows all LEDs, but doesn't show any sign of a fan or disks. Sometimes after showing the lights for a minute it will cycle off and back on. It does not beep or show anything on the display.
  • Anonymous Jan 09, 2009
    I have a hp 6000 that fell out of a freinds hands. The screen went dark . You can see o/s if you shine a light to it and open and work programs. I have replace a new screen and a back light inverter. However, the screen still remain very dark and o/s still works. Also if I hook up to external monitor it works fine. Just trying to get the screen to light back up .
    Frank
  • Anonymous Feb 22, 2009
    same problem
1) Turn off your laptop.  2) Remove Power supply.  3) Remove the battery and put it back again after 1 min.  4) Put power back and restart.
This should solve the porblem ! I have had it several times.
Posted on Nov 29, 2008
  • 502 Answers
The issue is usually caused by broken solder connections between some chips of the logic board and the PCB surface itself. There are two ways to fix this problem yourself. If you'd rather not do it yourself, you can have a third party laptop repair service do it for you but if you do prefer to do it yourself, you can reflow the GPU (repairs the solder connections) or replace the logic board alltogether. If you want to replace it, get the part and ebay and use a Laptop repair guide that teaches you how to install the part yourself. If you want to reflow, Google how to reflow a motherboard and you will find ways to re-heat the board to repair the solder connections, chances of success of DIY reflow are around 50%.
Posted on Jul 24, 2010
    Champion:
  • 230 Answers
Sounds like laptop over heat. Keep it off and turn it back on after it has cool down. Another things to check is your memory. Sometimes memory not secure to it "teeth" will cause this problem (like in my Toshiba).
Posted on May 06, 2008
My hp pavillion dv6000 works but , no light up screen . any suggestions?
If there is an image on the screen, but it is incredibly dark and washed out, then your laptop's back light is out. This is an expensive repair that often exceeds $300. Solutions can be having it repaired, getting it replaced, or using an external monitor with the laptop.
Aug 23, 2011 | HP Pavilion dv6000z Notebook
Tip
Recover HP Pavillion DV2000 + DV6000 + DV9000
Some HP Pavillion DV series have the issue of not starting up( screen is Black), lights are on, then it restarts over and over again.<br /><br />The solution is:<br /><br />Disassemble(open up) the Laptop with right tools.<br />When you get to remove the fan on top of the processor, you will see the processor and next to the processor an intergrated graphics card.<br /><br />Remove the processor.<br />Remove the Ram.<br /><br />What you do now is Get a hair blow dryer, set it to maximum hot air and blow 1 cm distance from graphics card for about 5 minutes.<br /><br />let it cool for 20 minutes.<br />Put back all components.<br /><br />start the POWER. wait and now your pc will show something like magic on screen..
on Nov 19, 2010 | Computers & Internet
Newer HP Pavilion dv6000 turned off while in use and wont turn on
1.Start your computer and see if your hear your fan noise,and cannot see anything on screen then there is problem with your power supply.
2.If you cannot hear your fan noise,and do not see anything on screen,then there is problem with your motherboard
3.if you hear fan noise and can see something on screen,then it is the issue with your hard disk (very less cases)
Mostly it would be the 2nd case that you will have to get your motherboard replaced
Jul 27, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion dv5-1113us laptop lcd screen backlight malfunction. My LCD screen is dark. There is no illuminated light to view browser, desktop, backgrond etc... Laptop boots up and runs but no screen...
I had same problem with HP DV6000. I ordered a new backlight on Ebay from Hong Kong cost $10 found a video on youtube on how to do it by typing in "replacing dv6000 backlight" apart from soldering a couple of wires was pretty straight forward and took less than an hour. Shop had quoted $400 to do this and fine is now working like new again. Good luck from Scott and please dont forget to vote
Jul 15, 2010 | HP Pavilion dv5-1113us 15.4" Widescreen...
Laptop Pavillion DV6188eu doesn't start up
From what you are describing, the motherboard has failed. I would however like you to try a couple of things though. First remove the hard drive and see if the computer will go to the BIOS screen. If it does not, then the Motherboard has definately died. If you can get to the BIOS, then you might consider a hard drive failure, or your windows installation is so corrupt, it is causing this problem. I would however lean toward a bad MOBO....seems this model, the DV6000 and the DV9000 have serious cooling issues and tend to burn their mobos up. HP recently started updating the BIOS files for these models so the fans and processor run more efficiently to keep the laptop cooler.
Nov 08, 2009 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
My laptop hp pavillion tx1000 satarts the light`s work but no have image on the screen the cpu fan and the hard disk works
Common issue on HP dv6000. You will need to get to the GUP and reflow it with a heatgun. Try this hp pavilion repair guide. It contains step by step instructions on how to take apart the system and fix the issue with the video. www.msbin.com/hp
Oct 15, 2009 | HP Pavilion dv6000z Notebook
Battery replaced, ac adapter replaced, still no
Could be the internal power supply unit... or in the worst case, the motherboard
Sep 27, 2009 | HP Pavilion dv6000z Notebook
HP Pavillion DV6000 won't start
It's a fabrication defect. For more info about it and free repair see here
Sep 19, 2009 | HP Computers & Internet
Blank screen
motherboard problem or
ram problem
Oct 26, 2007 | HP Pavillion ZV6000 Notebook
HP Pavilion dv6000z Notebook Logo
2,158 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
