Question about Samsung Digimax S500 Digital Camera
Thought the batteries in my camera were flat, changed them and as I switch on its just makes a beeping noise but does not switch on. I tried another set of batteries as well.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Beeping camera
Mine did the same thing for forever and was brand spankin new... When the batteries go dead once, I guess it glitches... You can put brand new ones in and it will Still say low battery or act like it anyway. Give it some time. Then try to turn it on again and it will be fine. Also it will say you have a low battery if you are taking too many pics at a time... like snap snap snap and it will shut down... turn it back on in twenty minutes and its fine... full battery. If you can't deal with this... Get a battery charger and rechargable batteries. I am using them now with none of these problems
Jul 07, 2008 | Samsung Digimax S730 Digital Camera
Olympus digital camera wont turn on again..
either the batteries are bad or the camera is defective. I'd get a set of premium batteries (Non recharble-cheaper) and try the camera with it. If it still doesn't work then the camera is defective you can have it repaired or buy a new one.
Mar 21, 2006 | Olympus Camedia C-350 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Samsung Digimax S500 Digital Camera Logo
14 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
