Question about Sony SDM-HS75/B 17" LCD Monitor
I have 17" sony black lcd monitor.. it has powersuply problem.. cant get pover.. how can i solve this problem
  • 11,361 Answers
You need to inspect and look at the pictures of failed monitor per Louie advise so you can make up your mind if you want to DIY repair or not.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Aug 29, 2010
  • 732 Answers
Kancanara, You will need to contract out the repair work ($40 to $90) or DIY investigate the "switch-mode-power-supply board/CCFL inverter supply" to determine exactly what electronic component(s) has failed, and more importantly WHY!!! Your unit will be 5 years old in 4 months! Did you notice if the WHITE web page background was getting a little PINK instead of pure WHITE? Have you performed the "flashlight test" to determine the "shutdown state" of unit's "switch-mode-power-supply"?? Have you verifyied proper operation of your PC with substitute "known-good" monitor? Will you be doing the repair after viewing some lcd monitor repair video clips at YOUTUBE?
Let us tech's here at fixya know your intentions as to exactly what you wil do. You should also spend some time researching the fixya profiles of "budmrtn" "buddymc" "12fixlouie" "louie12fix" here on fixya before making any decisions. 12fixlouie
Posted on Aug 28, 2010
Goes on for a second then blackout
the powersuply for your TL tube is shutting down.
you need to replace 3 elco electrical condensator in the powersupply 1*22/40V 2*470/25V after this the monitor will work fine
Feb 13, 2010 | BenQ FP731 17" LCD Monitor
How can Iget into the powersupply open the monitor
the powersuply is in the back of the panel when you open it so just look for for where you the power cord go and trace it from there
Oct 14, 2009 | Dell E173FPb 17" TFT LCD Monitor
Powersuply
OPEN UP YOUR PHONE BOOK OR YELLOW PAGES OR ONLINE LOOK UP COMPUTER SPECAILIST,
YOU WANT COMPUTER CABLING SPECALITY THEY CAN MAKE ANY TYPE OF CABLE OR CONNECT YOU CAN THINK OF AND EVEN HARD WIRE A CORD INTO YOUR SYSTEM SO YOU NEVER LOOSE ANOTHER ONE.
CANDYMANGANDY
Jan 19, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
NO PICTURE
Make sure it is plugged in with both cables.
Jun 17, 2008 | Sony SDM-HS75PB (Black) 17" LCD Monitor
Hp Monitor
There are about 6 caps in the powersuply. Please replace them
Apr 13, 2008 | HP L1702 17" LCD Monitor
Monitor goes Black off and on .....
I had the same problem for about a week and solved it yesterday by downloading the latest driver by NVDIA who makes my video card (NVDIA GeForce 6200).
I had previously updated the latest Sony driver for the monitor. It did not solve the problem but could be part of the solution in conjunction with the new video card driver.
Oct 31, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
SCREEN GOES BLACK OFF AND ON .....
LCD Monitor Goes Black during Use
I had the problem sometimes, but then I connected a second computer to the analog input and found out, that the screen didnt turn black but switches between the inputs on an on.
I found out that the "input" button seems to be short or damaged, as the behaviour was invertable by pressing the button. I blew into the button some times (a very naive solution, yeah) but it worked, the switching stoppped.
Oct 17, 2007 | Sony SDM-HS75P/S 17" LCD Monitor
Sony SDM-HS75/B 17" LCD Monitor Logo
231 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
