Question about Neff B1691 Single circotherm super Stainless Steel Electric Oven
Oven starts on std fan then displays "err" and shuts down. have tried power off at mains and waiting but keeps returning. Was intemittent, now a hard fault
    Sergeant:
  • 228 Answers
The ptc temp regulator has failed or gone too far out of range the oven will shut down for safety in case it wants overheat,it will need changing but is cheap and easy to replace.
Posted on Aug 27, 2010
Fisher double oven OD302. Periodically it will start beeping, shut off with no default code
Oven keeps beeping:
As there is no reprogramming of most control boards try this, disconnect the power and wait 30 seconds and then reconnecting the power.
If it's an "F1" fault code this generally implies an electronic oven control (EOC) failure. Disconnect the power, wait 30 seconds or longer and then reapply power. If "F1" returns upon power-up, replace the electronic oven control.
The oven control can be accessed and replaced from the rear of the control panel.
NOTE:Disconnect the power cord from the power source before removing the panel from behind the console.
If its an F2 ERROR CODE, The F2 error indicates an open circuit in the oven temperature probe.
Your range has a resettable thermostat in series with the oven temperature probe. If this thermostat opens the clock will display F2 and the oven won't heat.
You can reset the thermostat by pushing in the reset button on top of the thermostat.
Some ovens have an alarm that will beep continuously every six seconds to alert you that the oven is still on. Usually, a kitchen timer that you have set will cause the beeping, but occasionally it can be an error with the oven's settings. If it is the kitchen timer, you can simply push the "Kitchen Timer On/Off" button to end the continuous beeping. If that does not stop the beeping, it is probably beeping due to an error. You can turn the continuous beeping off but you may still need to troubleshoot the issue that is causing the beeping noise.
Read more :
http://www.ehow.com/how_12086370_ge-oven-stop-beeping.html
How to Get GE Oven to Stop Beeping eHow
Jan 09, 2017 | Fisher Ovens
Grandaughter leaned on Frigidaire Electrolux Professional Seriers oven and it now shows a red padlock display. We held down the button to unlock but it is not unlocking. Lost instruction manual. How do we...
First of all, without your oven's exact model number it is difficult to get the right manual and precise instructions for it, however here is the main ONLINE SUPPORT page for what is hopefully a similar model:
http://www.frigidaire.ca/product.aspx?productid=4725
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318205804en.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 22 of the ONLINE USER'S MANUAL for detailed instructions and illustrations on SETTING THE LOCKOUT FEATURE.
Basically you just press and hold the LOCK button for 3 seconds to either engage or disengage the lockout feature.
To clear off the F1 ERR code just press the CANCEL button.
If the problem persists, try shutting off the power supply circuit breaker for the oven at the house's main power panel box. Leave the breaker off for 5 minutes then switch it back on and try the oven again.
If this is not your model, just check your oven and let me know exactly what yours is and I will then provide additional information if necessary. Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Mar 06, 2011 | Ovens
Kitchenaid Superba walloven/microwave - problem with big oven.
I lost power and had the same problem. 177 degrees and ERR whenever I tried to change it. Reading the manual, I noticed that it was showing the degree symbol instead of F. When you hold down the broil/maxi/econo button for five seconds, it changes to F and then it worked perfectly. Makes no sense, but worked without any repairs needed.
May 12, 2010 | KitchenAid Ovens
Hobart electric convection oven model #cn90 ser. # 07-007-968-nj
Have you tried shutting down all power to your oven at the electrical panel, waiting 10 minutes and then returning power to the unit? Procedure could reset the defaults. Best of luck.
Apr 09, 2010 | Hobart HEC501-240V Electric Oven
F2E1 on stove after cooking on temps of 425-450 for 20mins stove shuts off and can not restart even if power is turned off and then started. must wait for stove to cool down and then press cancel and stove...
Is the background cooling fan running? Also, look under the oven and if possible take off the kick panel and clean all the rubbish out to ensure the cooling fan can circulate air round. As a check, when you turn any part of the oven on ( Main/top/grill) the cooling fan will run and you will feel a cool draft of air coming out of the gap just above the top of the main oven door. If the fan is not running, this will cause the unit to overheat and the overheat thermostats to kick in, turning the oven off.
If the fan is not running, you will have to take the whole unit out to gain access to the back panel.
Nov 28, 2009 | Stoves 720EF Electric Double Oven
My dacor oven model ECS130SBK is very slow to heat. Sometimes reaching the desired temp. after a long wait. Sometimes it never gets there.
I found the bottom element was not getting any power by using a volt/ohmmeter and a test method described elsewhere. (Shut off power, hold down COOK TIME while turning on power. then within 30 seconds press each mode you want to test and only that element/fan/etc will turn on. Cancels by itself after 30 sec.)
I traced the wire back to the relay (wire checked good) and there was no power getting through the relay although it clicked. Removed the relay board to replace it and found a cold solder joint on the "out" terminal with obvious past arcing carbon. Cleaned and soldered the pin and the oven now works normally.
WHY THE SLOW TO HEAT? The oven turns on all the elements to preheat faster and when it reaches your set temp it beeps and now only turns on the element you selected to maintain the temperature. (Bake or Convection) Our malfunctioning ovens would then cool since the element is not working properly and it must go back into preheat and keep cycling.
BY THE WAY- Don't ever use 4 hours on self clean it kills the boards and/or display. I also put a house fan in front of the oven and blow it into the lower grill to take away some of the heat on the two boards. Learned the hard way!
Jun 08, 2009 | Dacor ECS130 Epicure Electric Single Oven
Oven shuts down in middle of cooking
hI.
What is the make and model of your cooker?.
I do not know the answer at this stage, more information would help.
Cheers
Nov 23, 2008 | Ovens
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Neff B1691 Single circotherm super Stainless Steel Electric Oven Logo
136 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
