Question about Microsoft Windows XP Home Edition
My xp is not booting no in safe , no regular my question is if I reload xp from scratch will i loose all my data files in my documents?
  • 11 Answers
1. You can install Windows XP OS in another partition (another part of HDD). With this you will not loose anything.
2. If you want to ensure 100%, you can pull out your HDD and put to your friend's computer, open it with freind's OS and backup your files (also you can copy system files from your friend's computer to yours, it may help to repair your operating system).
Posted on Aug 27, 2010
My windows XP has an error message when started. It says "MISSING NTLDR, PRESS CTRL, ALT, DEL TO RESTART" I tried restart with boot disk but nothing. Please help!?
How to Fix NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
    Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
    Try replacing the IDE cable cable if you suspect it might be faulty.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will
Jan 22, 2014 | Belkin Basic Wireless Router
Windows not starting normally
Hello
If your OS, its now starting good, it depends, on a great amount of issues, from viruses, bad boot sector, bad drivers, bad boot files, or corrupted ones a lot indeed. but for help you quick, do these steps
1) go into safe mode, windows 7, xp,
2) verifify in control panel and device manager, if is missing any device, and then restart,
2) do in safe mode, an restore checkpoint **
3) if any of those not work, reinstall windows.
hope these help
Jan 05, 2014 | HP Compaq Presario SR1830NX PC Desktop
Recovering from malware attack
See the linked document on how to perform a repair install of Windows XP if you have not already done this.
Can you boot into Safe Mode or do you get the same hang issue when trying this?
As you can attach the problem XP boot drive as a secondary drive in another computer, I would recommend that you either backup all the user documents and data from that slave drive or that you make a backup image of the slave drive using any of the available backup tools such as Easeus Todo Backup or Paragon free tools
Dec 31, 2011 | Microsoft Windows XP Home Edition English...
I have windows xp media center edition 2005 and i have downloaded a driver for my new monitor lg E2250 and my computer have shut down.. since that i cant load windows i cant boot in safe mode for a...
Can you reload last known good configuration? Tap F8 as the computer boots up to pull up safe mode, etc options. If that doesn't work, you're SOL. The fact you cannot even boot up safe mode pretty much means you're hosed. If you have files on that hard drive, I would recommend pulling the hard drive out and getting the data off w/ a hard drive adapter. Once all files saved, I would wipe the drive and reinstall the operating system. Sorry. Situations like that ****.
Mar 12, 2011 | Microsoft Windows XP Media Centre 2005 for...
After booting up samsung NC10 error message saying windows could not start because following file missing/corrupt \windows\system\vgaoem.fon
OK, try, Boot Up in SAFE MODE, press F8 At Boot up, quickly, select, Boot to safe Mode desktop, with networking... simply copy vgaoem.fon file from xp disc or from net, paste file into windows system folder, done.
OR You could simply perform a system restore back to another time BEFORE you had a problem, again start up in Safe mode, F8. but this time when the choice is given to choose safe mode desktop or system restore, choose system restore, when a calendar like thing is displayed choose a time PRIOR to this problem happening, follow instructions and before you know it your PC will be back.
Oct 15, 2010 | Samsung Computers & Internet
I had to use my system recovery disc on my EMachine
When you used system recovery it is possible that some stuff got missed by pc. Nothing you did since i have seen it many times. You might wanna try reloading windows from scratch but be aware you will loose all the data of off it. This might be only way.while in set up for windows install make sure you delete old partition and then install new fresh copy of windows. You will need you OS XP disk for this. It is very easy to do so just follow the prompts and when it tells you do you wanna install new copy of windows so do and it will give you option to delete old partition and do a format on it. Once this is done just do regular install.Hope this helps.
Apr 06, 2010 | Computers & Internet
Acer Laptop Windows does not start up."system dll 32 file missing
take the drive to another computer to recover lost info then format it and reload a new install from the disk,then copy what you want back on to your computer,You will have a working system in about an hour
Hope this helps
Cheers MISTERDJ
Aug 16, 2009 | Acer Computers & Internet
HP Pavillion dv9000 will not boot up in normal mode, only safe.
Have you tried an XP repair?
Then you can save your data .
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jul 18, 2009 | HP Pavilion dv6208nr Notebook
Hai,
Try to boot the system in safe mode, if it boots up then ur lucky
otherwise go for a new installation and select a different partion if u want ur documents intact.
good luck
Rabby
Jun 17, 2008 | Microsoft Windows XP Home Edition
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
