Question about Veo Stingray
How can i connect my veo stingray in my desk top?
  • 19 Answers
SOURCE: Veo Stingray - with no disk
This fix will work for all of the VEO Stingray problems because it gives a good driver download site and it tells you step by step how to get your cam to work with VISTA Good Luck and let me know if this fixed your problems.
1.Go to this site and download the driver you need: http://www.softsci.com/veodrivers.htm
2.Download it to your desktop
3. Don't unzip, install, or plug in your cam yet
4.Search for this in your start menu: Program Compatibility Wizard
5. Of the three choices click the one that says look for the program manually
6. Choose the option for XP
7. Choose the 680 x 420 or whatever it is not the 256 colors
8. Choose to run as administrator
9. Click next and it should change your screen to a real big resolution and then it will start to install the driver
10. Go through the install wizard
11. After it has loaded plug in your camera
12. Try a program that it is supposed to work with
13. Finish the Compatibility Wizard
now everything should work for your cam.
This works with all of your programs that vista will not run.
Posted on Dec 31, 2007
SOURCE: veo stingray webcam vista compatible driver
Ok what you need to do is go to "computer" and right click on the drive that has your Install cd in it. Next click Explore. Then right click on "AUTORUN" and select properties, Under The Compatability tab change it to run in XP service pack 2 wait for it to switch, now click on AUTORUN and follow the steps. Worked great for my veo stingray 330
Posted on Feb 19, 2008
how can I get the software to install my veo stingray to my new computer that has vista on it
Posted on Sep 23, 2008
  • 5 Answers
SOURCE: how to install web cam veo stingray
download the driver for veo at:
when download is complete, click (open folder)
select the file (veo_330V_v002.exe) right click it
select properties
select compatabilty
put a check in box (run this program in compatabilty mode for)
choose (Windows xp (service pack2)
then apply
the double left click the file
and Bingo Vista will install it
I am using mine on yahoo messenger as I type now!
Have Fun
Hope this helped!
P.S. you can also download the suite from this sight
Posted on Oct 16, 2008
ruben1968
  • 3 Answers
SOURCE: Veo Stingray 304 driver
Hi. I had the same problem. I used Google and found
http://files.filefront.com/veo+304v+v1exe/;9569554;/fileinfo.html
The exact file that you want is veo_304v_v1.exe. This is where you will find your driver. And this is free too.
Hope this helps. Ruben
Posted on May 26, 2009
Why am i getting an error message
this is the most solution:: I had the same problem:
"Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Unplug the Veo Stingray from the computer.
IMPORTANT! If you are connected to the Internet (such as through a dial-up modem or cable modem/DSL) log off from your Internet Service Provider and disconnect any telephone cords or Ethernet/Network cables from your computer. This will prevent Microsoft Windows Update from attempting to update your Veo Stingray software driver through Microsoft Windows Update.
Place your Veo Stingray CD ROM into your computer.
Click on Start->My Computer. Look for your Veo Stingray CD ROM drive.
Right-click on the Veo Stingray CD ROM icon and then select Open.
Go to the E:\DRIVERS\APPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
In the cleanup program, press the "Scan and Delete" button in order for it to begin.
After the cleanup program has finished, click the "Exit" button and restart the computer.
Reinstall the Veo Stingray from the CD ROM, restart the computer, and plug in the camera after the computer has restarted.
good luck!
May 06, 2013 | Veo Advanced Connect Webcam
Where can I download software for veo stingray
I have the following sites on file - would appreciate any feedback to update the list
veo stingray/ connect 1.1.0.0
http://www.soft32.com/download_176111.html
veo stingray/ 330v
veo stingray/301v/302v/323v
veo 304v
http://www.camera-drivers.com/drivers/239/239330.htm
Sep 03, 2010 | Veo Stingray
Need software for veo stingray web camera 330v
I think I found the right software, it was not on the manufacturers site, so I found it on cnet, better known as download.com. http://download.cnet.com/Veo-Stingray-Connect-Web-Camera/3000-18489_4-69767.html?tag=mncol
Oct 31, 2009 | Veo Stingray
Need Vista driver for Veo Stingray
Just as a matter of interest see what happens when you test your webcam here - hit "allow" in top window and see if your webcam fires up in the left hand window
http://www.testmycam.com/
This is a long shot but may be worth a try.
There is no Vista driver I could find - you can try to run it in compatibility mode whichever your old system was
Don't run the program but save it.
Browse to that directory, right click on setup, properties, compatibility, set it to your choice or xp sp2 compat. close the properties. Install.
Aug 09, 2009 | Veo Stingray
Receive error code when trying to take snap shot with VeoAdvanced
I hope this sollution helps:
""Click on Start->Control Panel->Add or Remove Programs and uninstall the Veo Stingray software driver. Also, uninstall the Veo Digital Studio.
Go to the E:DRIVERSAPPBIN folder and double-click on a file named cleanup. (You can also download the cleanup file from: ftp://home.fiasj.net/xirlink/ibm/ibmcleanup.exe)
After the Veo Stingray has finished installing, try the Veo Digital Studio program again and click the "Take a Snapshot" button.
If it works, you can reconnect your telephone cord or Ethernet/Network cable to your computer. Microsoft Windows Update will not attempt to update the Veo Stingray driver again."
It might also be a java problem, go to Add/Remove Programs, uninstall all versions of Java, and try reinstalling."
Jun 23, 2009 | Veo Advanced Connect Webcam
Veo advanced
Oh for goodness sake why cant the message read "you broke it .... throw it away and get a new one" ?? At least u would understand that !!!!!!!!!!
Sep 28, 2008 | Veo Advanced Connect Webcam
Need help with veo stingray 330v webcam
hello i buy one camera veo stingray 330v only no see he softwareyou can help my email is ja_el_85@hotmail.com
Sep 04, 2007 | Veo Connect Webcam
Veo Stingray Logo
27 people viewed this question
Top Veo Computers & Internet Experts
micky dee
Lyle Siemens
Lyle Siemens
Are you a Veo Computer and Internet Expert? Answer questions, earn points and help others
