Question about Dishwashers
Dear sir my dexion dish washing machine model no gl 80DXDA LT-080-03-010. the problem is display PCB shows error & do some nonsense .
SOURCE: ERROR CODE F07 ON DISPLAY
Solved by heater replacement, cca 7eur in Belgrade.
Posted on Apr 06, 2009
  • 197 Answers
SOURCE: Hi I have a hotpoint washing machine model wt761
You have a blockage not allowing the drum to empty.
Check for blockages via the pump filter and the hoses
F05 means blocked pressure switch
If it still won't work come back to me
Posted on Oct 25, 2009
  • 136 Answers
SOURCE: my washing machine showing an OE error before end of cycle
OE error is noyhing but an Outlet Error.. OE simply means “the pump is blocked”. Clean and straighten the drain hose / clean the drain filter. Check the hoses (drain hose) and the pump filter but if it didn't cure the problem then turn the thing upside down and strip the pump out of it check if anything is caught in the impellor.. if so remove it and everything will be fine..
Posted on Jan 18, 2010
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
ginko
  • 19396 Answers
SOURCE: Hi, I'm looking for a
Hi.
Unfortunately Gala does not make any documentation available for online download.
The GL95LA should be the 5Kg 800 Rpm model.
To get the manual click and open Gala page here, then scroll down Gala page and fill the form titled"Contact us about 5Kg Gala Washing Machine 800rpm" .
In the form write model number and part number of the washer, as printed on servvice tab and ask to send you a manual for your appliance, possibly in PDF format.
Regards.
Ginko.
Posted on Aug 30, 2010
Error code E000064-0000
E064-0000 Description The presence of a high-voltage error is communicated by the composite power supply PCB (The output for primary charging, developing, or transfer has deviated from a specific level of voltage) Causes The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty. proce Remedy 1. Contact Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact? YES: Clean the contact, and set it once again. 2. Wiring Is the wiring between the contacts for the following normal: DC controller PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller? a. DC controller PCB (J301) <-> composite power supply PCB (J136) b. composite power supply PCB (J130-7) <-> primary charging roller contact c. composite power supply PCB (J130-1) <-> developing assembly contact d. composite power supply PCB (FT133) <-> transfer roller contact NO: Correct the connection. 3. Composite power supply PCB, DC controller PCB Try replacing the composite power supply PCB. Is the problem corrected? YES: Yes. NO: Replace the DC controller PCB
Nov 19, 2014 | Canon Ir 3300 Black & White Copier
Canon ir 3300 error code e000803-0000
Similar to Description The 24V output from the composite main power supply PCB is absent for 1 sec or more Causes The wiring is faulty (short circuit, open circuit). The composite power supply PCB is faulty. The DC controller PCB is faulty. Remedy 1. Connectors Are the connectors J204 on the main power supply PCB and the connector J300 on the DC controller PCB connected securely? NO: Connect the connectors securely. 2. Main power supply PCB Is 24 V supplied by the main power supply PCB (J204) to the DC controller PCB (J300)? (J204-5 <-> J300-5: OVU3, J204-6 <-> J300-6: OVU3, J204-7 <-> J300-7: 24VU3, J204-8 <-> J300-8: 24VU3) NO: Replace the main power supply PCB. YES: Replace the DC controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/joshua_ac64e182ed26f66d
Aug 21, 2012 | Canon Ir 3300 Black & White Copier
How can I reset alarm F21 on Bosch washing machine type WIM40?
Dear Sir,
it is requested you that we have a washing machine Type: WIM40 & RN # WAE20463tr/12 it has still showing error on display as "F21 alaram" Kindly resolve it or tell us solution that what will be.
Best Regards,
Imran Khan Nawab
May 13, 2012 | Bosch Washing Machines
I HAVE A CANON IR 3300 MACHINE I HAVE ERROR E00000-000
WHAT: Either the main thermistor doesn't attain 30?C 1 second after the power switch is activated or it doesn't attain 70?C 2 seconds thereafter.
WHY: It has a faulty fixing film unit, lack of connectivity with the main thermistor, lack of connectivity with the fixing heater, a faulty main power supply PCB, or the DC controller PCB is faulty.
NOTE: You can reset the error by performing the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
CONNECTOR FIX: Make sure that the connector of the fixing assembly is seated.
A. main power supply PCB (J8) relay connector heater
B. DC controller PCB (J320) relay connector thermistor
FIXING FILM UNIT (THERMISTOR) FIX: With a multimeter, check the interval between pin 1 & pin 2 & between pin 3 & pin 4 of the connector (4-pin) of the thermistor for electrical continuity. A result of ?? means that the circuit is open (lack of connectivity). Resolve this by replacing the fixing film unit.
MAIN POWER SUPPLY PCB, DC CONTROLLER PCB FIX: Press the Start key. If the drive voltage of the heater is supplied by the connector J8 of the main power supply PCB, then the main power supply PCB should be replaced. If not, then the thermistor control mechanism is faulty & the DC controller PCB should be replaced. Use the following to ascertain this:
Main heater: between J8-1 (FSR1) & J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) & J8-5 (FSR COM)
Sep 25, 2010 | Office Equipment & Supplies
I have lg top loader washing machine model wf583spc if i start any program after 30sec the De error blinking please give the guide line also drain clear & door ok but always show same problem
I HAVE LG WF-583 FULLY AUTO W/M AND MAIN CONTROL PCB IS DEAD IN THIS M/C. WHERE SHOULD I GET REPAIRED/ REPLACED THIS PCB AND WHAT WILL BE EXPECTED COST?
Aug 17, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Image source 50 code E64
E064 Error code details Power supply voltage error (high-voltage error)
0000 The presence of a high-voltage error is communicated by the composite power supply PCB.
(The output for primary charging, developing, or transfer has deviated from a specific level of voltage.)
Main cause
Action
1. Contact
2. Wiring
 YES: Yes.
 NO: Replace the DC controller PCB. pls rate for my good deed!!!!!!!!Good Luck
Sep 21, 2009 | Office Equipment & Supplies
E90 IS THE ERROR CODE IT IS SHOWING
E90 is a communication error between the main pcb and the display pcb.Check the blue wiring loom that goes from the main pcb to the display pcb.normally it is a bad/loose connection on the display pcb end.clean pcb tracks and tighten the blue connector loom pins up and hopefully it will work.if it doesn't solve the problem then you could have a faulty display pcb or main pcb.
May 02, 2009 | Washing Machines
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
