Question about Refrigerators
The lid on our new Norfrost chest freezer does not fit well causing frost build up
  • 4,793 Answers
Start with a spirit level and ensure the freezer is level all round (with the lid up.)if the feet are not adjustable, use spacers,then close the lid and if you have to,use a hot wet cloth to mould the seals to fit correctle(flat to frame) check with a thin piece of paper to ensure no air leaks.do this before you try to adjust the hinges,
Posted on Aug 27, 2010
Testimonial: " Thank you very much - just what we needed."
Chest freezer ice is building up on the inside lid
These ideas ****. Question was, what causes ice to build up in the chest freezer.
Jul 03, 2012 | Kenmore 5 cu. ft. / 142 liter Chest...
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Dec 13, 2011 | Freezers
Just bought Belling Chest Freezer Model BCM31 as old one was thick with ice, but new one is frosting up very quickly as well above food line. Is this normal? Setting is right in the middle.
open the lid and using a spirit level check that the unit is flat and that its not "twisted" then using an a4 piece of paper check that the lid sits flat all round with no air leaks (the most common cause of chest freezers frosting up)if you have one, a freezer thermometer is a good investment, as you can set the unit to run at -18C,the optimum temp,,,
Sep 06, 2010 | Belling Freezers
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
I keep having frost and ice build up in the upper corners of teh freezer. It will make it difficult soon to slide the doors open. What could be the problem?
Any freezer without automatic defrosting will build this up over time but a poor gasket seal between lid and chest can accelerate the buildup of frost.
If you want to check the quality of the seal, you could use food coloring (I'd choose green or blue) in water, add a drop of dish detergent and apply this mix to the sealing surface of the chest. Closing the lid gently and then reopening it, you may be able to see if the contact between sealing surfaces is as it should be.
The mixture will wipe off easily with a clean cloth or paper towel.
Apr 30, 2009 | True 598-THF29FL Horizontal Spot Freezer...
Frost in Chest freezer
Not much you can do except ensure you have a tight seal and not to open it more than you have to.
Oct 23, 2008 | Zanussi 10.31 cu. ft. / 292 liter Chest...
Kenmore 12 Chest Freezer - Needs New Lid
searspartsdirect.com
All you need is the model number
It gives you a list of all parts you can buy to replace what's broken, as for the frost try placing a sheet of plastic over the insulation, under the the plastic cover to keep moisture and humidity out of the insulation.
Apr 25, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
We have a Chest type Freezer, Model is GLFC1526FW. A lot of ice build up near the top of the freezer. And the freezer lid is cold to the touch. And the bottom part of the freezer, no ice build-up. Is,...
yeah , the coil patern of most chest freezers run the evaperaton loop around the top of the freezer down about 6 to 8 inches to start the frost patern, knowing that cold air falls it then works down and cools the rest of the freezer and its contents hope this fixed your problem
Apr 20, 2008 | Refrigerators
Refrigerators Logo
350 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
