Question about Dewalt DW082K Laser Levels and Rotary Lasers
Cant take apart all screws removed still wont come apart (dewalt dw082 laser)
What is the battery direction on dw082
Page two of the manual: http://www.homedepot.com/catalog/pdfimages/2a/2a31f6dc-ae10-4cbb-a0cc-190a7132d0d9.pdf
Feb 19, 2015 | Dewalt DW082 Laser Plumb Bob
Dewalt how to take apart
Remove the 3 screws holding the foot on and remove it.
Slide the insulator and blade clamp lever off exposing the gearcase.
At this point you can remove the gearcase from the handle and can access the entire tool.
Removing the gear assembly will require removing the nut (#18) at the front of the gearcase (under a plastic cover) (best done with a 13mm socket on an impact driver) then removing the blade clamp assembly allowing the mechanism to slide out.
Jul 29, 2014 | Dewalt Dw938 18v Reciprocating Saw Sawzall...
Dewalt 743 how to replace the brushes
If the motor body has two large screws on the outside, then you can remove them and install new brush set. If there isn't, then you have to take the motor apart and install them. Try to look up the saw and get a parts break-down picture or drawing first.
Mar 24, 2014 | Dewalt Saws
Have a screw head stuck in the chuck .. it was a small bit and now wont pull out.... help
Just took apart a DeWalt, the chuck has a left hand scew that holds chuck in place, may be the problem
Jan 20, 2011 | Dewalt DW056 18 Volt Cordless Impact...
I have two dewalt 1/2 electric drills and the extension cords are cracked. how can i replace the extension cords?
You will need to lay the drill on a bench then remove all the screws that hold the two halves of the case together, carefully pull the case apart to expose the wire connections
Mar 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How can I take a part my dewalt 12 volt drill
Hi there, Remove the battery and sometimes the screws on the drill casing are a torx instead of phillips so you will need a set of torx screwdrivers. Once you have removed the screws from the casing be very carefull when pulling the two casings apart, try to leave the chuck, motor and switch assembly in one half of the casing as it makes it much easier when trying to put it back together.
Jan 01, 2010 | Dewalt DC727KA 3/8" 12v Cordless...
I have a dewalt dc925 combi drill the chuck keep slipping and also the setting ring is hard to adjust . What can i do top solve this?
Probably needs a new transmission. They cost about $34 plus shipping. Easy to fix. Just remove the four torx screws from the metal (gray in color) part $of the drill. Then pull it apart. The transmission comes in a one piece cassette. Insert it, and put the front back on and tighten the screws.
Mar 10, 2009 | Dewalt 2 Dc925 18v ½ Hammer Drill /...
Dewalt DW082K Laser Levels and Rotary Lasers Logo
80 people viewed this question
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
