Question about Panasonic SDR-H40 HDD Camcorder
Whwn i am trying to download the data to the computer it shows connect the ac adapter...what is i? and how can i fix
    Genius:
  • 1,812 Answers
The AC adapter is the cord that plugs into the wall socket and connects to the camera to provide constant, uninterupted power.
Posted on Aug 27, 2010
How can I connect my computer to a wifi hotspot I have a Linksys AE 1200 Wireless-n- USB adapter that I installed and it shows that I am connectted but when I try to open internet explorer it says I a
It seems like you are missing the CD you need to fully install this adapter. However, you still can download this data at this link. Since you have Windows XP, click the download link under where it reads 'XP Driver'. Feel free to respond if you need further help.
Dec 29, 2012 | Linksys Computers & Internet
My Seagate Expansion External Drive just stop working. Whene ever I connect the power cable it making bip sound repeately several times and stop. and the drive doesnot show in My Computer. The drive is...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Feb 21, 2011 | Seagate (ST310005EXA101RK) 1 TB USB 20...
When i m connecting ac adapter in dell inspiron 1525 it show u connect 65w or higher ac adapter laptop is working condition
Hi Maxinfotech Its a common problem for DELL laptops. Most of the time the cause of this a bad AC Adapter but sometimes a firmware reset for the motherboard is the fix. I recommend you try replacing the AC adapter first than try to reset the firmware which could cause a system malfunction sometimes when not done properly. Thanks for using Fixya
Feb 11, 2011 | Dell Inspiron 65W PA-12 1525 LAPTOP
For some reason my Hitachi external hard drive is not showing up on my computer. I know that once i plug it in it should show up on My Computer but its not. What should I do??
* the USB cable
* the power-adapter
Dec 13, 2010 | Hitachi SDM/250RW 250 GB USB 2.0 Hard...
When i plug in my WD External Hard Drive 500gb it show to be un readable in disk managen ment and gives no options to fix it
* the USB cable
* the power-adapter
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
Dec 09, 2010 | Western Digital 500GB My Book Pro-External...
Not showing in computer
* the USB cable
* the power-adapter
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 12, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
I noticed a ticking sound coming from my external hard drive. Then I noticed it was no longer showing up on my system listing. Is this worth trying to fix? Mark
* the USB cable
* the power-adapter
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device, and maybe to upgrade from 100GB to 500GB.
Nov 11, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Battery empty message when connecting olympus sw 1030 to laptop
Your recharged battery may be weak. May be time to replace.
If the battery power runs out while the camera is connected to a computer or printer, the image data may be lost or damaged. It is recommended that you
use the AC adapter. Do not connect or disconnect the AC adapter while the camera is connected to a computer or printer.Do not remove or load the batteries or connect or disconnect the AC adapter
while the camera is turned on. Doing so could affect the camera’s internal settings or functions.
Sep 02, 2009 | Olympus Stylus 850SW Digital Camera
Seems like power source in back of 1150 inspiron is loose
appears to be a loose connection between the AC adapter and the computer. Inspect the port on the computer where the AC is being connected for any damaged. If available, try using another known-good AC with your computer to isolate if the problem is specific to the AC adapter. If the same thing happens with another AC, the motherboard needs to be replaced. If the warranty of your computer is still active, contact dell and request a replacement for the motherboard
Feb 02, 2009 | Dell Inspiron 1150 Notebook
Panasonic SDR-H40  HDD Camcorder Logo
42 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
