Question about Cell Phones
NOKIA 2630 cable
I bought a cable, but the software requires ser2pl.sys file not available on cd.
    Problem Solver:
  • 10 Answers
DO A GOOGLE SEARCH SHOULD FIND IT WORKED ON MINE
Posted on May 07, 2008
I have a dell dimension 8400 with a TSST CORP TSH492B cd-rw/dvd drive. Windows only sees this as a cd-rom and automatically uses the following drivers storprop.dll cdrom.sys imapi.sys redbook.sys. I...
those are the basic drivers for all cd. dvd, and rw drives. if you are trying to use the drive to burn a cd/dvd you need to purchase software for it your download a free burning software from filehippo.com called xpburner or burnerxp i cant recall the exact name
Apr 14, 2011 | Samsung (TSH492BLACK) CD-RW/DVD-ROM Combo...
Can not find file path for ser2pl.sys to open registry of Garmin golf gps
Its a registry issue. Install the driver off their website on another computer (the legacy driver, not the one that says first download driver. its on the same page) and get that ser2 file from your system 32 folder, copy it to the other computer.
Mar 16, 2011 | Garmin Golf Logix GPS
Need file pathway to open registry
Please click on the link below to download the missing file(ser2pl.sys):
downloads/ser2pl.sys
Copy the file in C:\Windows\System32\Drivers .
Mar 16, 2011 | HTC Touch Pro2 Smartphone
Itunes knocks out DVD/CD driver whenever I update Itunes.
Solution 1
Check with your manufacturer to see if there are updated software drivers for your optical drive. For more information about updating the firmware of your CD or DVD drive,
Solution 2
Launch Windows Explorer.
Navigate to C:\Windows\system32\drivers\.
Check to see if either of the following 2 files are present. These files from a third-party software vendor are not supported by Windows Vista and can cause driver conflicts with optical drives:
afs.sys
afs2k.sys
If either of the files in Step 3 are present, move them out of the system32 folder. You should keep these files stored somewhere on your hard drive, as some of your older peripherals may require them. If you find that they are required in the future to use a device, you may move them back into the system32 folder temporarily.
Reboot Windows Vista.
Solution 3
Quit iTunes.
Manually remove the GEAR driver software using the steps found here.
Remove any stand alone GEAR software installers from the Programs and Features control panel, if present.
Install the updated GEAR driver.
Mar 06, 2010 | Toshiba SD-R5272 DVD±RW Burner
Scanning
Hi saly_60,
You can try the following steps to resolve the issue:
1. Connect the USB cable directly to a USB port on the computer Ifyou are connecting the device through a USB hub* or other USB device,disconnect it and try connecting directly to a USB port on thecomputer. If successful, the problem may have been with the device.
*Somescanners are powered by the USB connection. This is why connecting thescanner through another device, such as a USB hub, may prevent thescanner from communicating properly with the computer.
Connecting the cable to the your device.
usbtoprtr.gif Connecting the cable to your computer.
2. Check USB Connections Youshould disconnect and reconnect the USB cable at both ends to ensurethere is a secure connection on the device side as well as the computerside. It may also be necessary to try a different USB port on thecomputer. Additionally, you may need to disconnect other USB devices,temporarily, in order to determine if a conflict exists. .
  1. Disconnectone end of the cable and then reseat it ensuring the cable is firmlyseated into the USB port. If the USB cable is plugged into a hubinstead of directly into the computer, try connecting the USB cabledirectly into the computer.
  2. Repeat step one to reseat the cable on the other end.
  3. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  4. Make sure the correct USB cable type is being used.
  5. Incorrect (A to A) USB Cable
    Correct (A to B) USB Cable
3. A device attached to the computer is blocking communication If you have more than one device connected to your computer, thenit is possible that some other device is blocking proper communication.
  1. Check to see if there are any devices (other than USB keyboards or mice) connected to the computer.
  2. Disconnect the device(s) and restart the computer.
  3. Once the computer has restarted, attempt your process again.
4. Press the ON/OFF button to power on the device. The device has an <ON/OFF> button.
  1. Connect the power cord from the device to the electrical source.
  2. Press the <ON/OFF> button.
  3. Wait until the device has completed its cycling process before submitting a job request or completing installation.
5. USBSCAN.SYS USBSCAN.SYS is a Windows system fileand required by the scan driver. If the system file is missing, anerror message will appear while installing the scan driver or willappear when attempting to scan. Search for this file and direct theinstallation to the appropriate path.
Search USBSCAN.SYS file on Windows XP:
  1. Click 'Start', 'Search' and select 'For Files or Folders'.
  2. At 'Search Results' window, type usbscan.sys in 'Search for files or folders named' field.
  3. At 'Look in' drop-down menu, confirm your computer's hard drive is selected. In most cases, C: is the computer's hard drive.
  4. Click 'More advanced options' link.
  5. Confirm checkmarks appear beside 'Search system folders', 'Search hidden files and folders and 'Search folders'.
  6. Click 'Search' button.
  7. Once search has completed and if the file does not exist, download a copy of usbscan.sys from here (Right click and select ‘Save Target As’).
    1. Ifthe file exists and a message appears while installing the scan driver,direct the installer to the appropriate path. For example,C:WINDOWSsystem32drivers.
  8. Close the 'Search Results' window.
Search USBSCAN.SYS file on Windows Vista:
  1. Click the Start button.
  2. Inthe Start Search box of the Start menu, type 'usbscan.sys' (without thesingle quotes) and then press 'Enter' on the keyboard.
  3. Once search has completed and if the file does not exist, consult the computer manufacturer.
Uninstall and Reinstall the Driver If the MP Navigator or the MP drivers are no longer required, or if they are not installed correctly, uninstall them. Caution:Uninstalling means deleting software, such as MP drivers, from thecomputer. Once the software has been deleted the unit cannot be usedthrough the computer until the software has been reinstalled.
Note:Login as a user with Administrator privileges to uninstall onWindowsXP/2000. Turn off any programs running in the background, suchas antivirus programs and firewalls before begining.
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
6. Reinstall the Drivers
Use the CD-ROM that came with your printer or download from canon website.
Sep 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
The file LV561AV.SYS on logitech USB Video camera Disk is needed
If you have driver/software CD of that webcam, then please try to reinstall it. It might work. If not then...
The same file is also available with Logitech Webcam
This is the site where you can download the Logitech drivers...
http://www.logitech.com/index.cfm/435/4266&cl=us,en?WT.ac=sc|downloads||dd
After downloading all the driver files... you can look for the file LV561AV.sys in it.
This is all I could find.
Please Rate if you find the above info of any use.
Dec 09, 2008 | Labtec 961307-0914 Webcam
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Aug 05, 2008 | ICP DAS I-7561 CR (I7561CR) Serial Adapter
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
Motorola L6 Mobile phone
Well if one of you friends have V3i or L7 ask them to give the Phone tools cd they got with it.
Install the program first then plug in you L6.
It worked on my PC
Nov 23, 2007 | Motorola Mobility L6 Cellular Phone
Cell Phones Logo
62 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
