Question about Car Audio & Video
My carbattery went flat i changed the battery and the radiohass locked it self and i need a code to get it bak on
  • 6 more comments
  • tarshan09 Aug 27, 2010
    its a eurovox stereo
    its a factory fitted eurovox car stereo for a holden vs aclaim
    1995 model vs holden commodore aclaim
    its a holden commodore 1995 aclaim the stereo is a eurovox originally came factory fitted with the car
    hi i changed the battery in my vs holden aclaim commodore and the steroe reset its self now its asking for a pin or security code its a eurovox stereo and it was factory fitted
    can you help me out with this problem
    thanks mate for that solved for me
    thanks for the great help
  • 11,800 Answers
You must take the papers or another proof that you own the car and go to your local Holden service dealer. They will provide you with the code and they don't ask for a fee . Or you can take the stereo out about an inch, the code should be on the top or side of the stereo.
Posted on Aug 27, 2010
  • 560 Answers
Is it a factory fitted unit or an aftermarket like Kenwood, Alpine etc?
What car is it?
Relationship between A 12volt carbattery and an IMA Hibrid battery
different internal construction
talk with an accredited battery retailer for exacting differences
May 01, 2017 | Cars & Trucks
Battery went flat now with a different battery check engine light is on can it be reset using the key switch
Probably not. Most need suitable diagnostic equipment to clear codes and those older models that do not simply disconnecting the battery for a few hours will generally do the trick. Sometimes it is possible to access codes and clear them by triggering self diagnosis by shorting selected pins of the obd socket.
A few older models fitted with an immobiliser can have the immobiliser code inputted by using a combination of key switch, brake or throttle pedal or the driver's door lock depending on manufacturer.
Oct 06, 2015 | Cars & Trucks
Vw beetle radio code
the radio locked it self out you will need to call the dealer to get the unlock code
Jan 24, 2014 | 2004 Volkswagen New Beetle Convertible
Replaced the Carbattery, now the keyless remote
when you replace the battery in a newer vehicle the computer module becomes reset and the codes for you hand transmitter are deleted. you need to take your vehicle in to have it reset. this will help you.
Mar 08, 2010 | 2003 Saturn VUE
Battery went flat now wont take key code in drivers door 1994 p38 range rover.did some engine work battery disconected for about a week. when engine work finished.conected batery started fine. went...
key code lock out usually happens when you have entered the wrong code too many times leaving the battery connected should allow the timer to run down for 30 mins so you can try again, it is cumulative though so the more you get it wrong the longer you have to wait. make sure battery is fully charged first.
Jan 30, 2010 | 1994 Land Rover Range Rover County
Can't start motorbike
Hi!
Sometime things like that happens
Since it almost start but the battery dont last enough to go all the way i sugest you you connect a car battery with cables to your battery. The car battery is stronger and last longer, that will start your bike. You can do it for a couple of minist but i dont rekomend you to do it longer, Since the carbattery is stronger it can cause damages on you startengine if you have it connected to long. But when your bike starts you wont need the carbattery anymore, revome the cables immidiately.
Good luck
Nic
May 28, 2009 | 1997 Honda Steed
Jetta wont start
serious electric problem, i think is the computer module try to get code with a mechanic
May 26, 2009 | 1996 Volkswagen Jetta
Wat could be wrong
yep ! sounds like a blown diode inside alt. have it tested either on or off car voltmeter should read 12.35 volts or more, any less replace the unit. i would test the new one at the parts store. prior to install
shack
Apr 19, 2009 | Nissan Pulsar Cars & Trucks
MY SCREEN HAS BROKEN DOWN
i have an hp so idk if this will work . . . take the battery out of ur laptop and let it sit for at least 5 hours ............ and then put it bak in . . . if it still dont work . . . . check the side of ur screen . . . if u see a little hole in it and beside it is a picture of a lock . . . get the smallest flat head u can find or a strong needle and switch it up . . . wait an hour and switch it back . . . one of those two solutions should work if not write me bak and i have a few more things for u to do and it will work urs hopefully - eli (write me bak )
Nov 20, 2008 | Fujitsu AMILO PC Laptops
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
