Question about Xerox Document Centre 420 DC Laser Printer
It says on the display 'do not ready to copy' and also 'memory full' what to do?? help please"! thank you
    Scholar:
  • 92 Answers
Does this happen when using a specific feature? If not, you can try to unplug the device directly from the power cord. Wait 15min and plug all back in and turn the device on.
You can follow this: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=487,E=0000000002258725222,K=6075,Sxi=1,Solution=obj(1025)
If the issue happens when scanning then you might want to try scan reducing the resolution to the minimum to check the behaviour.
Posted on Aug 27, 2010
Memory full on parrot V5.11C how to clear
Please follow the below procedude
Hold the answer and hangup buttons down for 5 seconds {press red and green and hold} the parrot kit will then tell you it is erasing memory then it will say ready for pairing,
Turn on your bluetooth on your phone do a search find and select parrot.Enter default code 1234 when prompted as a pin.
Thank You
Nov 28, 2012 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Phone memory full & phone book full
Sir/Mam
Please try by delete some file(s) or the image(s) that is not useful to you and see whether it display the same problem.
If not please Copy or move the file(s) or the image(s) that are useful to you, in other storage like Memory card.
Thanks for using FixYa!
Oct 08, 2012 | HTC F3188 Smartphone
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
My Nokia E63 display a message of ' Phone memory full " and also says 'Please delete files'. Which files to delete and how ? Thanks. Partha
I woud clean up your mobile phone by:
  • Copying your photos on your handset to your PC/Laptop and deleting most of the photos as they can take up a large amount of memory.
  • There are physical available memory limits to the total number of SMS/Messages in your Inbox/Outbox/Sent/Other folders: delete old SMS/messages.
  • There are physical available memory limits in the total number of contacts: delete all redundant directories entries.
You can also try using a bigger microSD card to alleviate your memory limitation.
Hope it helps.
Dec 14, 2010 | Nokia E63 Cell Phone
W910i can not save the pictures. I was working fine before
Hi, first for the pictures captured to be saved, might be that your phone memory if full and no other place for it to save the pictures.if you have an external memory card, change the storage device to save to memory card in your camera settings.
And secondly, if you want the call logged call registry to display, you will have to copy the numbers into the phone memory before the call logg can display callers identity.
Hope it helps.
Take care.
Jun 01, 2010 | Sony Ericsson W910i Cellular Phone
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Ready Memory Received
Dear guys, your toner cartridge is low and as a preventive measure, the unit stores the faxes in order to give priority to copying and printing. If you are using remanufactured cartridges, the unit might not be displaying the low toner warning.
Jan 24, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Please help: readout says "no memory space" but memory stick is empty!
When you copy pictures to your computer you still have the pictures on your camera so there is need to clean them up my reformatting memory stick.   This procedure will leave the memory stick clean and ready for a new set of pictures.  Here is how you reformat the memory stick-:
1.  Insert the memory stick to be cleaned/formatted in the camera
2.  Turn the MODE DIAL to the SETUP position on the camera
3.  Switch on the camera
4.  Select the MEMORY STICK TOOL from the CONTROL BUTTON
5.  Press the centre of the CONTROL BUTTON
6.  Select FORMAT by using the down arrow and up arrow
7. Choose OK by moving the right arrow button
8.  Finally press the centre of the CONTROL BUTTON and this will start reformatting the MEMORY STICK and it will ready for reuse.
Enjoy your new space in your Memory Stick!
Oct 24, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Open Questions:
Dear Sir, I am very happy if you could talk to From Rector Divine Union Seminary Ayyappankavu P.O . 680 751 Mulayam Trichur 0487 2315166 To Manager Customer Care Xerox India Ltd 20th Floor DLF Square Jarcada Marg M-Block Gurgaon ? 122 002 Email: Digital.solutions@xerox.com Respected Sir, I am writing this letter to bring to your kind notice and attention a serious problem concerning the Xerox 0420 photocopier. We had purchased the machine on 06-12-2007 from your noble institution paying a huge amount of money. It is very sad to say that it is the second time that the copier is not working well and needless to say that there was no necessity of replacing the drum cartridge either. That is to say that we have not taken even 12,000 copies. Within this time we had to replace once HVPS which costs nearly 27,000/- rupees. We replaced it on 11-10-2008.Again we are confronted with the same problem. The machine is not working well again due to the dysfunction of HVPS. It is also very sad that this part cannot be repaired. When we use the copier the copies are not clear and show ?U9? code. And the service personnel from the Trichur Computer Clinic is asking us to replace the HVPS. We had purchased the machine through ?Trichur Computer Clinic? (TCC). And we were not given even 1 year warranty instead they gave us only 3 months; though the warranty card shows one full year of the purchase. Dear Sir, it is impossible for us to pay you another 27,000/- to purchase a new HVPS. To do so it seems like putting one?s own foot into the hole of a snake. We feel thoroughly cheated by you and our trust and confidence in the company is shaken. We hear similar complaints from many buyers and even from the service engineers. It is at their advice that we are writing this letter. We would like to hear from you soon .I hope you will be kind enough to take up this matter as an urgent case and do the needful as early as possible. If we don?t hear from you we will be forced to take up the matter to the consumer court . Yours Sincerely, Rector Fr. Antony Pittappillil sdv Email:pittappilly@gmail.com
Dec 15, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox Document Centre 420 DC Laser Printer Logo
69 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
