did you try cleaning the lens???? if not try that and see what happens.
SOURCE: Carousel does not rotate from one cd to the next
I just had the same problem with my parents dx-c206. I first found the motor drive unit with quite a bit of dismantlement, the drive circuitry is under the turntable as well for the drive motors. Once in the drive motor unit, the associated circuitry is clearly seperated on the circuit board between the drive and the actual cd spin motor and laser circuit, I checked all the voltages to common and all seemed fine, I then discharged the caps, and it then by itself started to spin again, it still has a few glitches, that it might freeze, could have been also a faulty cap. Real reason is unsure, this was a lucky fix... I did also remove what I presumed is a coil sensor unit that is also located under the turn table, once the small rectagular circuit board is removed u will find two U shaped (presumed magnetic sensors). I dought that any cleaning I did fixed this, but this could possibly have been infra red sensors, that would requirer some cleaning. These sensors are responsable for the turntable positioning.
SOURCE: malfunctioning cd player
Did you try taking out that lttle circle thing that you put your cd into.Well,take that out and then clean it.Then,insert it back and it should play your cd
SOURCE: hI i HAVE A WHIRLPOOL
Hello SPENNA,
There could be many reasons for this to happen. Here are a
few that comes to mind:
HERE
is a superb article on all the steps you can take to rectify this problem. It
is a bit lengthy to post here, so PLEASE follow the link. It will definitely help
you resolve this issue.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
If, however it has not, then please do not assign a
rating just yet. Please post back as to
what steps you took, results, etc, and I will try to assist you further as
best as I can.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: home cd player will not open
Look underneath the unit for an access hole . It may be labeled as such.
Some CD units offer a manual drawer open device under there.
If you're really brave, unplug the unit and remove the case screws. Pop off the case and get your CD back. The you might need a draw belt. See prbline.com or studiosoundelectronics.com
