Question about Maytag MSD2758G Side by Side Refrigerator
HOW TO I PUT MY CHILD LOCK ON MY LG FRIDGE FREEZER?
The control panel on my jenn air fridge model # jfc2089htb is not responding and I cannot adjust any setting. Fridge is stuck at 44f and freezer -1f
A simple reason could be the control panel is locked (child/safety lock) - look for a small lock symbol in the display.
Oct 30, 2016 | Refrigerators
GWB227wlqa. Why is the panel on the front beeping?
If you haven't yet... unplug it for 15 mins without opening the doors.. check the plugs on the bottom that run into the door panels unplug and plug them back in again. Making sure they are clean and fully pushed together.
Aug 06, 2015 | LG Refrigerators
Whirlpool 6th sense fridge freezer electronic panel - how do i unlock? child lock not on
Emma:
The lock and unlock feature is accomplished by holding the lock button for 3 seconds, and you will see a count down number just above it that indicates 3, then 2, then 1, and a soft tone along with the lock icon appears. To reverse this hold the same button for 3 seconds following the same procedure and the unlock icon will appear.
Jul 14, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Removing LG refrigerator control panel
Put your model number into a repairclinic.com or go to YouTube.com there should be a video on either site showing you how to remove that panel
Mar 02, 2014 | Refrigerators
Have had this refrig. for several years and have had no problems until our 2 year old grandaughter played at the temperature controls about a week ago...The freezer has been set at -2 and the regrigerator...
Hi there
Samsung's child lock is easy to alter
Press the vacation and fridge temp buttons simultaneously and hold for 4 seconds, this will release the child lock, to reinstate the lock just repeat this. 4 seconds is quite a long time.
Hope this helps
Gordon
Apr 20, 2011 | Samsung RB215LASH
Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Jan 03, 2010 | Bosch Classixx KGV28323 Bottom Freezer...
Ice Maker Hookup for LG side by side with freezer on bottom. We connected the water line to the fridge to the connection in back.... both connections, the one up top and the one on the bottom. We are not...
ok...1st there is only one connection to the fridge at the valve.2nd check the filter and see if one is present.3rd make shure the child lock out feature on the dispencer is not activated.
Aug 06, 2009 | LG LFX25971ST Bottom Freezer French Door...
LG DU-30LZ30 30 in Television missing remote
Try this http://www.remotes.com/ See if they have it
Nov 15, 2007 | LG DU-30LZ30 30 in. HDTV LCD Television
Maytag MSD2758G Side by Side Refrigerator Logo
960 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
