The picture is stretched vertically and does not show the whole screen missing out all the edges. Screenres currently set to my computer monitor of 1920 x 1080. Thanks
  • 82 Answers
Change to a lower resolution
Posted on Aug 27, 2010
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
Monitor screen display stretched center but squashed/narrow edges
On the monitor itself, I am guessing this is a desktop? There are buttons for adjustment. Look for the menu button around the bezel of the monitor and press it. Scroll through the settings for the default setting and press that. Once the default settings are made for the monitor, then you can go to the graphics settings available through windows to get the resolution straightened out.
Mar 26, 2010 | Computers & Internet
Screen stretched out horizontally and distorting picture. None of the settings buttons appear to solve this. I can shift the image vertically or horizontally; but not squeeze it horizontally.
There are adjustments in the size of the items on a screen under the screen properties, settings. If you right click on the desktop screen and then properties you can get there. There is at least one size which causes a distortion of images being displayed. This may be your problem.
Feb 28, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
3 inches of black on both sides of my monitor
I have seen this when using HDMI cables from the computer side.. The TV has a resolution that is not always full screen with TV shows. There is a setting that allows you to "zoom". My TV has 4 settings: normal, stretch and crop, stretch left and right, stretch and pinch (shrug).
Jul 07, 2009 | Hansol (720ESB) (Black, Silver) 17 in.CRT...
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Picture not filling monitor screen
what is your sceen resolution set at on your laptop. try adjusting them and see if that works.
mj
Nov 01, 2008 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Monitor Problem
This is probably the result of using the wrong display driver. It may even be set for an external monitor. If it was used with an enternal monitor, connect it up to the same one (or something similar) and use the display settings to get the computer to use the LCD as the primary.
Jul 09, 2008 | Acer Aspire 5002WLMi Notebook
Display appearing stretched
the original image size was probably recorded in 4:3 aspect ratio...meaning your widescreen is a 16:9 ratio size screen and is stretching it outwards to fill the whole screen. If you want the image to look normal.. ie. not short and fat people.... you need to change the picture size in the settings from widescreen 16:9 to normal 4:3 tv in the settings menu most likely...Also most remotes will/should have a button for that.
Oct 26, 2007 | ViewSonic VA1912wb 19" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
