I want to install the adobe reader programm and not r ispond
rosener
  • 103 Answers
SOURCE: sound card
Hi Zigma,
Some internet applications needs video and or sound stream controls needed some file to run or view. In this case, you can hardly tell what downloaded programs you have installed that overrides the default installed drivers. In some case upon uninstalling some program it will ask "are you share to remove the shared file xx.xx?" Now to regain back the sound card driver you had. You must check the sound card driver at control panel sound settings property. Remove it or update the driver you will need to. Note: check if any the soundcard driver file properties has an error marked. This helps you determine the drivers fault or conflicts.
Best regards,
Rosener Guyano
Posted on Feb 02, 2008
  • 2692 Answers
SOURCE: How to install adobe acrobat reader 9 when 6 is installed?
Adoby acrobat reader 9 is a free download from their website:
http://www.adobe.com/products/reader/
Posted on Jan 27, 2009
AmitGoyal007
  • 3 Answers
SOURCE: I CANNOT INSTALL ADOBE READER 9.1 ERROR MESSAGE 1402 APPEARS
Do the following solutions first of all please remove all previous versions of Acrobat, and then reinstall.
1. Choose Start > Control Panel (Windows XP)
2. Double-click Add Or Remove Programs.
3. Select Adobe Acrobat [version] and click Remove.
4. When prompted, confirm that you want to remove Acrobat.
5. Repeat the above procedure for all installed versions of Acrobat.
6. Restart the computer, and then reinstall Acrobat.
Now, perform the steps below during Acrobat Reader installation. The Administrators group listed below is the default local administrative group for Windows XP.
  1. Write down the path to the key referred to in the error message and leave the installation running. For example: HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler.
  2. Choose Start > Run, type regedit in the Open text field of the Run dialog box, and then click OK.
  3. Navigate to the parent of the key referenced in the error message. For example, for the key HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf\PersistentHandler, open (double-click) HKEY_LOCAL_MACHINE >SOFTWARE > Classes > .pdf.
    Note: These steps may vary slightly depending on the path in the error message
  4. Right-click on the parent key and select Permissions (HKEY_LOCAL_MACHINE\SOFTWARE\Classes\.pdf).
  5. Verify that the Administrators and SYSTEM is present and that Full Control is selected under the Allow column.
  6. In the Permissions dialog box, click Advanced.
    cid:1f55f5d78f3846839533f8a85e395973@joanne
  7. Select the Administrators group (1) and "Replace owner on subcontainers and objects" (2). Note: Select the current administrator account if the Administrators group is unavailable.
    cid:3ce74f38956e4dfcae487444ce8f86c9@joanne
  8. Select both "Allow inheritable permissions from parent to propagate to this object" and "Reset permissions on all child objects and enable propagation of inheritable permissions," (1) and then click the Owner tab (2).
    cid:be8ff9254ad94f29bec91706f67dc76b@joanne
  9. Click OK (3) in the "Advanced Security Settings" dialog box. Windows will now reset the permissions for each child object to correspond with its parent.
  10. Minimize the Registry Editor and click Retry.
    • If the error reoccurs with the same key proceed to Solution 4.
    • If the error occurs with another registry key repeat Steps 1-10 using the new registry key.
    • If the error does not occur finish the installation following the on screen instructions and exit the Registry Editor.
Please let us know how it goes.
Posted on Jun 16, 2009
  • 312 Answers
SOURCE: cant install adobe reader on my pc as error
You can read adobe reader new version and install that...If your OS is XP, it will support all adobe readeer....I think your download is not perfect.please try the above way...Hope you will succeed....
Posted on Nov 23, 2009
smb_146
  • 252 Answers
SOURCE: I had/have Adobe Reader 8.1.1 and recently installed Adobe 9
first uninstall adobe reader 9 and then adobe reader 8. After that re-install adobe reader 9.
it may work. try
SMB
Posted on Nov 27, 2009
I have downloaded books from Barnes and Noble to my computer, now I don't know how to get them to me ereader. When I plug it in it just says emode and I don't know what to do
Observe the requirements of computer document decoder programmes. For example, adobe acrobat reader performs functions either capturng to display media from several devices. Once installed, adobe acrobat reader on the computer, documents that are instaled or introduced from elsewehere that require decodes eiher as encoded on various formats are decipherable. Ascertain either with computers on network connections to downloader the latest version of adobe acrobate reader. While on the internet, acquire the most compartible to computer. Significant notes includes that adobe acrobat likely requires program components either as flash media players, to complement to attain multimedia experices on computers that capture resources in various formats.
Feb 21, 2011 | Computers & Internet
What is FoxItReader and how is it used?
Just like Adobe Reader. When installed It launches when you double on a pdf file. for more details read here http://en.wikipedia.org/wiki/Foxit
Dec 29, 2010 | CTX EzBook V92C266 Notebook
Tried to download a pdf file and 'Runtime Error' flashed up. This application has requested the runtime to terminate it in an unusual way. Please contact the application's support team for more...
Try unstalling and re-installing Adobe reader. Hope it would fix the problem with acrobat.
Else, you may download latest version of acrobat reader and install it. the problem could be with the file. it has nothing to do with the operating system.
Hope it helps. let me know if any clarification is needed
Nov 04, 2010 | Adobe Acrobat Reader 3.0 for PC/Unix/Mac
My Adobe reader has stopped working - this happened when I tried to download a pdf file. it flashed up 'Runtime Error' this application has requested the runtime to terminate in an unusal way. Please...
Nov 04, 2010 | Adobe Computers & Internet
I need an instructional manual for the 12-Cup Programmable Coffeemaker - Black Model # CUI DCC-1100BK
You can download and print the instruction manual in PDF format by clicking this link
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
Aug 08, 2010 | Cuisinart 12-Cup Programmable Coffeemaker...
Je veux installer adobe gratuit dans mon ordinnateur. aider moi merci rachid
Aller ?:https://www.adobe.com/products/reader/
Cliquez sur T?l?charger- Download
cliquez sur l'ic?ne qui s'affiche sur votre ordinateur et lancez le programme -Run
suivez les instructions
Jun 21, 2010 | Adobe Acrobat 6.0 Professional for PC
Some how adobe deleated from our computor. now we cant get our e-mail or anythig that requires adobe
You can download Adobe Reader again from the following link:
Adobe Reader
Download the programm from the link above and after it finishes double click to install it and follow the on screen instructions.
Jan 28, 2010 | Adobe Acrobat 4.0 Full Version for PC
it may work. try
SMB
Nov 24, 2009 | Computers & Internet
Documents load into notebook instead of pdf(adobe)
right click on the document you want to open, select "open with", it will bring a window up asking what programme you would like to open the document with. If there is nothing in the window click on "browse" then choose adobe and click on the adobe reader icon, make sure you check the box that says "always use this programme to open this type of file"
all your pdf's should now open in adobe reader from now on
let me know how you get and please rate my help
regards
Nov 25, 2008 | HP Computers & Internet
Sound card
Hi Zigma,
Best regards,
Rosener Guyano
Jan 14, 2008 | Computers & Internet
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
