Question about LG Flatron 575MS 15.1" LCD Monitor
LG Flatron 575MS 15.1" LCD Monitor Need 24 volt power supply
  • 11,361 Answers
  • alkarim_15 Aug 30, 2010
    Thanks for your reply but its definitely 24v DC power supply 1.2Amps. The model no is LG Flatron LB8575EE.
  • 732 Answers
Alkarim 15, Are you looking for an "open frame" switcher or a "open frame" linear dc supply. Does it need to have regulated output or if linear type just brute force output.What is the current requirement of the circuit you will use with the power supply? Have you checked www.jameco.com or www.digikey.com or www.newark.com . Does it need to be AC or DC output? 12fixlouie
Posted on Aug 28, 2010
Same power supply board LG L1910s and L1510s ?
just look the amper rating in the power supply if they are the same.
Sep 20, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
I want by a power supply to LG FLATRON L1510S
The question is not very clear and if this is a commercial request it would be better that you can contact any of the power supply distributors in your area. However if the LG SMPS is required it must be sourced from the LG service support.
If you need to check on the SMPS please check this link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Nov 21, 2011 | LG Flatron L1510S 15" LCD Monitor
LG Flatron L1515S 15" LCD Monitor Problems & Solutions
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 18, 2010 | LG Flatron L1515S 15" LCD Monitor
LG FLATRON L1953T-SF 17" LCD Monitor Has no power? I checked the fuse, it's OK, tried different cords still no go? would it be the power supply itself?
Did you inspect the caps, any bulging one? Measure the power supply to see if you do have 5v and 12v on the power supply/inverter board.
See pictures and websites so you will know what to look for:
Apr 15, 2010 | LG Flatron L1715S 17" LCD Monitor
Ho w can i get driver for my flatron touchscreen lcd monitor to activate his features
LG Flatron L 1510S LCD Monitor Drivers : Download from this website:
http://driverscollection.com/?H=L1510S&By=LG
open directly link and download from website, then install in your PC. Your problem will be solved
Jan 29, 2010 | LG Flatron L1510S 15" LCD Monitor
LG L1920P flatron just flashes
Check the + 12 and + 5 Volt voltage coming off the power supply board. Look carefully as the +5 volts might be breathing.. meaning varying between +3.89 up to +5 and then cycles again.
Jan 04, 2009 | LG L1920P 19" LCD Monitor
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
LG Flatron 575MS 15.1" LCD Monitor Logo
388 people viewed this question
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
