Question about Microwave Ovens
I dont know how to use induction cooker.it has no numbers to reduce the heat.things will burn very fast
  • Microwave Ovens Master
  • 17,130 Answers
You can use to set the timing in order of the heat required. Also using the grade rating of the heating coupled with the time set, the food can be easily heated without burning.
To start with use low heat and long time, the try with medium heat and lesser time and then choose high heat and short time. You must be able to use the settings accordingg to your requirement.
Hope this advice helps
Posted on Aug 27, 2010
How do I fix induction cooker which does not start anymore?
try to unplug it and plug it back. Make sure that it is turned off first before you unplug it.
Aug 24, 2012 | Microwave Ovens
E6 displaying in Induction cook top
my problem is E6 code & 1 or 2 minutes automate stopping
Jun 05, 2012 | Microwave Ovens
Fissler Pressure cooker has steam coming out from the Utimax valve, is this normal?
Hi. Some steam is ok. But when it is running it should be sealed up. The little rocker should be doing it's thing too. Good luck.
Jul 25, 2011 | Microwave Ovens
I have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the...
Dear Sir i have an prestige induction cook top model PIC 3.0 the problem is that it displays an E7 error whenever switched on after appx. 1 minute and the food is not boiled /cooked. please let me know what is the problem How Can Solved this Problem This prestige induction cook top model PIC 3.0 Only one week so please do need full
thx... Kundan singh Rana Baddi (H.P.) 09857455945 ranansd@gmail.com
Mar 23, 2011 | Microwave Ovens
The induction cooker when put on it shows E6 after about a minute or so and no heating takes place.
There is a error message there, it indicate a problem with your induction cooker. It cause a defective winding wire or circuit controllers your know induction cooker works similar to the principle of electro magnet induction, it give heat to metal cooking pot. I hope I give you a idea regarding what happen to your unit.
E1 error was shown on induction cooker.Please give me a way to solve this.
Possible that the driver of the induction coils is short or damaged. You might need to remove the panel and check within to see the reason for the protect cut off.
If there is no other display on switch On then the circuit is faulty and a knowledge of power electronics is needed to probe into the circuit.
Mar 16, 2011 | Microwave Ovens
I have a prestige Induction cooker... a new one. When I tried to turn it on for first time, it just shows "-- -- -- --". Post this, even after placing a induction cooker compatible vessel, it...
We have a Prestige Induction cook-top Model PIC 3.0. It gives the error "-- -- -- --" and a beep when the power is turned on. Can anybody help. My email is asbhambra@gmail.com
Mar 11, 2011 | Microwave Ovens
I have a new induction cook top. When using for the first time I found an F or P appeared next to the element I was using. I have bought stainless steel cookware specifically to use. The user manual...
Stainless steel (or Aluminium) cookware will not normally work with an Induction cooker: Induction cooker need cookware that have a certain amount of metal especially at the bottom of the pot or pan.
An easy way to check if the cookware is suitable is to use a small (fridge) magnet: if it stick to the pot/pan then it is very likely that the pot/pan is suitable for induction 'magnetic' cooking!
Hope my small hint is of assistance and if so, vote accordigly!
Oct 03, 2010 | Westinghouse Microwave Ovens
Type s333 2006 microwave will not heat. Everything is good but the microwave don't heat
this could be a number of things, fuses, megortron, capacitor,
but what ever it is dont try to fix it yourself there is over 1000 volts kicking about inside it and if you tuch this your going to grow wings prity fast, have you ever seen a stun gun working? well inside your microwave it there very big brother!!!! but it dont stun,,, it kills
look at it this way,,, whats your life worth in £????? play it safe,,, call a guy in to fix it for you, ok
Oct 20, 2009 | Panasonic Microwave Ovens
Microwave Ovens Logo
156 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
