Question about Nokia 5200 Cellular Phone
I'm using nokia 5200(java supported). 2 days ago it was dropped into water....then i immediately put it into sunlight.now call button(green button) and menu button is n't working.
  • Nokia Master
  • 17,129 Answers
You should not have put the set on unless it was opened and cleaned out of all moisture, It is possible that the set has failed in the sensitive circuits because of water in the circuits.
The best you can do is to open the set and use a good magnifying glass clean the points of the IC , usea hair dryer to enhance the moisture to move away.
repeat the process and keep the board to dry before you set it back. However if there is no result I am afraid the hardware hass failed. Get estimate from a Nokia service and decide.
Posted on Aug 27, 2010
  • 1 more comment
  • zankarandall Aug 27, 2010
    hi sorry i should of been a little clearer in my post the phone was well dried out with a hair dryer and working fine for a couple of weeks and then the select button and call button stopped working all of a sudden if i put pressure on the slide part or tilt it a certain way the buttons start to work again..
    just read my original post sorry buttons only stopped working 2 days ago not dropped in water 2 days ago sorry
  • Donald DCruz
    Donald DCruz Aug 27, 2010
    Ok, So since the phone is working except the two button functions, it is possible that there is some moisture logging in there or has corroded. If possible use a thin needle to clean these points use a good lens to see track loss or line break, clean the pads and try.
Batteries and phone very hot
There is a short in the phone that causes a high rate of battery discharge resulting in a overheating battery.
This cell phone is faulty and I suggest you get a new cell phone.
May 21, 2013 | Nokia 5130 Cell Phones
I have dropped my E5 into the bath
Immediately remove the phone from the water,turn off the cell phone remove the battery and SIM card. When you have driedthe cell phone by putting in a warm sunny place for several days or in front of a warm fan heater for several hours then reassemblethe phone. Hopefully it will work properly but if does not work then it isfaulty and you need a new cell phone.
Jun 27, 2011 | Nokia E5 Cell Phone
The *3 and call button does not work to reformat my nokia 5200?
it will not work on a nokia 5200 as it is a java phone, you can do factory reset from setting, or do a software update with nokia software updater online, if your phone is giving problems.
if this dosent solve you need to flash phone from a good service center
Dec 23, 2010 | Nokia 5200 Cellular Phone
I took my memory card out my phone to print off photos but now there all gone and my phone won't read the memory card. need help?
Your memory card may be damaged. Here are steps you can take: 1. Put your card into a card reader and see if you can access it on a computer. If you can, immediately back up all the data onto your computer. 2. If the card is detected but all the data seems erased, use a file recovery software such as iolo Search and Recover 2. 3. If the card is not detected, I'm sorry but you may have lost all the data. Your best bet is to put it into a Nokia 5200, or Nokia 6085, or similar Java based Nokia phones. Restart that phone and hope the phone corrects problems in the card. Then repeat steps 1 & 2.
Hope this helps :)
May 16, 2010 | LG KU990 Viewty
My mobile is not being swith On
Make sure not to turn your mobile immediately
Dry your mobile first
Your could use blow dryer to remove get rid of the moist inside the mobile
then when you're sure that the mobile is already dry try turning it on
if the mobile doesn't turn on your mobile has already short circuited
Aug 21, 2009 | Motorola Cell Phones
Call button and menu button is not working
its problem flex know change it know its ok 10000%
Mar 15, 2009 | Nokia 5200 Cellular Phone
Help me find a dictionary for nokia 5200
Hello Sir, You can find a dictionary on GETJAR.COM as u r using Nokia 5200 ur mobile supports java platform and is of series 40 edition You can not only find dictionary but also many softwares on that site For any further assistance you can write to me on my id: funky_2_chunky@yahoo.co.in
please do rate my solution
Thank You  Vinay Ramani India
Oct 28, 2008 | Nokia 5200 Cellular Phone
Java
when i start the mobile its hang in menu please tell me how i can formtat or update the software
Sep 13, 2008 | Nokia 5200 Cellular Phone
Unlocking nokia 5200
Follow the instructions give below & unlock your mobile using unlock code by making use of this site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
Warning : Do not enter any wrong unlock codes on your Nokia 5200 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 5200 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 5200 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5200.
3 - Compose #pw+CODE+1#.
4 - The Nokia 5200 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 5200 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 5200
Jul 03, 2008 | Nokia 5200 Cellular Phone
Nokia 5200 Cellular Phone Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
