Question about Vacuums
HI THERE, IS THERE ANY CHANCE YOU MIGHT BE ABLE TO GET YOUR HANDS ON A MANUAL FOR - WELLARD SUPER AUTOMATIC 802 - SEWING MACHINE - HOPE SO - THANKS KIM
Hi I have a Janome 419S or 423S, the problem seems to be my hook race unit keeps getting loose and then the thread jams up. What can be done? Please
A jammed machine is caused by thread being caught in thehook. Remove the upper thread and the bobbin case, turn the hand wheel towardsyou (counterclockwise) by hand and remove any thread in the bobbin case area. Alwaysturn the hand wheel towards you. Turning the hand wheel away from you(clockwise) can cause the machines timing to become unaligned and jam yourmachine. Also, always make sure the presser foot is in the down position beforeyou start sewing. Sewing with the presser foot in the up position will jam yourmachine in the bobbin case. If youhave an older model sewing machine with a shuttle hook, then you can alsofollow these: 1. Disconnect the sewing machine from any power source.Loosen the thumb screw on the left side of the sewing machine body and removethe cover to expose the needle bar. This is the shaft that extends down andthat you attach a needle to for sewing. Open the shuttle race and remove the bobbinand bobbin case. 2. Turn the hand wheel toward you until the needle hasreached the lowest point of the stroke. The hook should be at the top of itsstroke inside the shuttle race. Loosen the set screw for the needle bar on theupper part of the machine, this is located on the needle bar bushing (thecollar that the needle bar slides through when making a stitch). The needle barshould slide easily up and down. 3. Turning the wheel again, adjust the position of the tipof the needle so that the upper part of the needle eye is just below the bottomedge of the hook inside the shuttle race. Once in position, re-tighten the setscrew on the needle bar bushing. Do not allow the needle bar to slip whiledoing this. 4. Replace the bobbin and bobbin case and close the shuttlerace. Thread and plug in your machine. Using a sizable scrap of cloth, sew aseam to check to see if there are any skips in the stitching. If there arestill skips re-adjust the timing again until you can sew without any skipped stitches. 5. When proper timing has been achieved replaces the coveron the needle bar and tighten the thumb screw. Hope this will help you. Good Luck.
Sep 13, 2011 | Vacuums
Looking for threading diagram for singer stylist 514 sewing machine
Hi tusnig,
You can get a manual for your machine at the following website: http://www.mastersewusa.com/info_s533.html
Copy and paste the address into your browser and go.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 21, 2011 | Singer Vacuums
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I have a New Home My Excel 15S MS 3015 sewing machine which I inherited from my mother, but I don't have the instruction manual of how to use it. Need help with threading the bobbin, the machine, and...
Hi Madelyn,
Here is a website where you can download the ms3015 user manual: http://www.managemylife.com/mmh/owner_manuals/20778/JANOME-Mechanical-Sewing-L0905091?brand_name_search=Janome+new+home+ms3015
I hope this helps. If it does, I'd appreciate your 4 thumbs up vote. Thanks,
Handie Andie
Apr 16, 2011 | Vacuums
I just baught this singer sewing machine #AF049505 have know idea on how to thread it.i have no manual for it.dont know anything about it any help that you can give me on it would appriciate it. thank you...
Hi there!
Singer has available product manuals online. You may need to determine which model do you currently have. If you're not sure, check this link to view your current machine model: http://new.singerco.com/products
Once you have that info, go to this link: http://www.singerco.com/accessories/manuals.html Key in the product model number then click on Search.
You can also check this link for the sewing machine's basic operations guide: http://www.singerco.com/resources/operation_basics.html
Hope that helps!
Jan 31, 2011 | Vacuums
Is it possible to download a manual for my recently purchased used Shark Intelli-Sew Europro Model 9110 sewing machine? Thanks in advance for any help you can give me... Kitty...
You could download the same from :-
http://www.sharkclean.com/manual/9110_REV_0104E.pdf
You need to have acrobat reader to view the file.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 08, 2010 | Vacuums
Sewing manuel for singer sewing machine 9015T
Hi
Try the Singer website. http://www.singerco.com/accessories/manuals.html
Just type in 9015, do not include the letter T and click on search.
A list appears on the next page and a free download is available.
I'm not sure what your machine looks like as you have posted this in vacuums!
I hope it's the right manual for your machine.
Sep 27, 2010 | Vacuums
Kenmore YM-40-35 R Sewing Machine Manual (or copy) wanted. If a manual is not available, I'd be OK with instructions for threading the needle and bobbin and any additional details that an expert may...
Please go through the below document which will give you the help you wanted:
http://www.ehow.com/how_4798790_thread-bobbin-kenmore-sewing-machine.html
http://www.ehow.com/how_5839_thread-sewing-machine.html
http://www.youtube.com/watch?v=1j8e8FvwUlQ
You will also find additional information on every page at the left hand side (Ehow.com) and on the right hand side(Youtube).
Please let me know if you need any additional information or have any information that you would like to share with me.
Jun 10, 2010 | Vacuums
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
