Question about Dishwashers
My Bosch Logixx atuo diswasher is just draining all the time. There isn;t amy water in the machine it's like it's got stuck on that part of the programme. Tried switching the macjine off at the mains but when you switch it back on it just carrys on draining.
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Bosch Diswasher not draining
Soyben, you need to check to see if either the drain hose or syphon break at the sink is clogged. The drain motor on this model is not a bilge pump that will remove water from the base. Therefore Im leaning on a restriction somewhere. Other than that you may have to check for debris in the drain sump. Check these areas out first...Catriver...post back
Posted on Aug 27, 2006
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
  • 3 Answers
SOURCE: Bosch Dishwasher SHV4313GB/17 Wont switch off !
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills OK, then this ISN'T a solution to your problem. If your machine doesn't fill but your drain motor continues to hum for no apparent purpose, this may work.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
Posted on May 09, 2009
SOURCE: On my Bosch dishwasher Excell
I solved the problem, by tipping the dishwasher back about 45degrees, I think this re-adjusted the flood sensor, and it is now working fine. Thank you.
Posted on Jan 11, 2010
PCB isnt locking the door, what relay or other part is in charge of sending the signal to the door ?
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine leaks from the front (see video tutorial on this) ... I have a Bosch washing machine which is leaking from underneath and the water ... It did work with no load in the drum on a 30 wash. ... Hi cecilia this is not enouth info on this fault but i would start with door lock and checking wiring to pcb.
Bosch Washing Machine Parts - RepairClinic.com
www.repairclinic.com/Shop-For-Parts/.../Bosch-Washing-Machine-Parts
Huge selection of Bosch Washing Machine parts in stock. Same day ... Door Boot Seal - Part # 1388885 Mfg Part # 00667489 · Skill Level: .... Front door sleeve.
Bosch Logixx WAS28440AU - ProductReview.com.au
www.productreview.com.au > ... > Front Loaders > Bosch
Rating: 3.4 - ‎74 votes
3.4 out of 5 stars for Bosch Logixx WAS28440AU in Front Loading Washing Machines. ... I've been quoted $895 to replace the PCB board plus technicians time plus have .... We're sorry to hear that you're having issues with the door locking on yourBosch WAS28440AU Washing Machine and .... This isn't limited to Bosch.
Jan 12, 2016 | Bosch Logixx WAS2446 Front Load Washer
My bosch classix 2100 washing machine takes 3 hours to finish a 30 degree wash.is this normal?
If it gets stuck on 1 minute for a long time, it is possibly the heating element which needs replacing. They can get covered in scale in hard water areas and stop working. Replacing the heating element in my Bosch Logixx solved the problem.
Sep 27, 2013 | Bosch Washing Machines
I have a Bosch Logixx 8 1200 When i turn it on it bleeps and f 37 comes on but it is in a warm dry kitchen, the door won't lock, when I hit the temperature button twice the frost light appears ?
this a problem water level switch
Remove the air hose from the water level switch, and blow into the hose,as hard as possible, to clear any debris that may have accumulated in the hose.
Remove the lower panel, and remove the filter from the drain pump and check and clear any debris from the filter and the interior of the pump, and hoses.
Oct 02, 2012 | Bosch Washing Machines
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
F:23 code logixx edition75
Usually means there is water in the base pan and the flood safety has been activated. If you tip the unit forward a touch you will most likely find that water is expelled from the bottom front. The machine should work but obviously the source of the leak has to be found. Check door gasket for tears etc, water valves and drain hoses.
Hope this helps.
Jul 07, 2010 | Bosch Logixx WFT 2806 Front Load...
Blocked drain
try to disconnect the drain hose under the sink and put the machine in drain mode this will **** the water out of thge hose. if the water is blocked in the machine you have to get a torch screwdriver and take of the plastic piece in the center of the unit . that is where the propellor is. then close the door and put the machine into drain. the stuck partical should reverse out.then place cover back on.that should do it
Apr 05, 2010 | Bosch 18 in. SRS55L02 Logixx Slim-Line...
Bosch 2460 washime machine. washed, will not drain r spin
i think thew buzz you hear maybe something stuck in the pump impellor. remove filter and check
Jul 23, 2008 | Bosch Logixx WFT 2806 Front Load...
Dishwashers Logo
Top Dishwashers Experts
