Buzzing/humming noise in my computer's power supply
I have a power supply (550w max output) that started humming/buzzing this week. It is not very old, I only bought it a few months ago when the first one went out. I leave my computer on all the time, so I'm not sure if maybe I'm not supposed to do that and I've overworked it, or if something is just going wrong in it. Yesterday, I took it out and cleaned it with that air-in-a-can for cleaning electronics and it stopped for a little while, but it's buzzing just as loudly again today. Sometimes it even starts to sound like it's going to go off, then it'll rev back up and buzz steadily again.
    President:
  • 2,351 Answers
Most power supplies come with a one year warranty. Contact the manufacture for a replacement.
Make sure the power supply is mounted snuggly & it's not vibrating.
Mike
Posted on May 06, 2008
  • 4 Answers
I wouldn't recommend leaving your PC on all the time but don't think this should have harmed your new power supply. The power supply may be faulty so try speaking to the store you bought it in to try another one. Alternatively, I would try moving your PC to a very well ventilated area at your desk to see if this helps.
When I put my PSU on the ON position, it makes no noise, but when I turn it off, it makes a hissing noise and does the same if I unplug it. It was bought two weeks ago and made noise when I first used it,...
if its only 2 weeks old should and its brand new be under warranty
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hope this helps and good luck building your first computer
Apr 29, 2011 | Eagle Tech ET-PSVT550E 550W ATX12V v2.0...
I have a 32 inch vizio with internet apps. every time i turn off the tv a humming/buzzing noise that won't go away unless i unplug the power adapter! When it's on it works just fine.
Tv power supply board have input and output high voltages issues.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 27, 2011 | Vizio L32 32 in. LCD HDTV
Power on are compressor, hear buzz, but pump did not start .
if its just humming and not starting you may have a motor start capacitor on the motor thats bad and can't supply the starting voltage against the compressor
May 09, 2010 | Campbell Hausfeld 28 - Gallon Air...
My computer restars while nfs shift on max settings games config : 9600gt, asus p5k, 4 gb ram, 3 500gb hd, 1 sata lg cd dvd burner
Hi, if your computer restarts this means that your computer lacks of power..you a running 3 hard disks drives ?? + 4 dvd writer ..try to unplug a hard disk the dvd drive and unused usb devices and see if your computer can handle playing on maxed out setting if yes then upgrade your power supply unit for a 550w ;) enjoy
Jan 17, 2010 | ASUS Computers & Internet
Can you supply pinout for Dell AA23300 Power Supply ?
On the main plug there is a single green wire. Jumper the green wire to any black groung wire in the plug and the fan will start and you will have output.
Nov 03, 2009 | Dell AA23300 550W Power Supply (X0551)...
Making a humming/buzzing noise and then cuts off.need help.
Have you checked the Lamp to see if it has shattered? This is the most common reason for this symptom. It is accessible from the back left side as you look at the set.
I hope this helps,
Skyassoc
Oct 25, 2009 | Toshiba 42HM66 42" Projection HDTV
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
A couple of weeks after initial setup of my brand new Onkyo XT-SR606 receiver, I noticed a loud buzzing noise that starts up approximately 10 min after the receiver is turned on. The buzzing is definitely...
The "buzz" you hear is a power hum made by the power supply transformer. It's technically called "Lamination hum" caused by the revering of electrical current through the power supply transformer. In some cases the hum can vibrate the chassis causing other loose material to vibrate. If you can, go to your dealer and check to see if other units of this same type typically make a hum this loud, and if not, see if he can solve the problem for you.
Feb 27, 2009 | Onkyo TX-SR606 Receiver
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Onkyo HT-SR800 buzzing noise present then vanishes
The hum a fluorescent light makes is the 50 or 60 Hz hum of the alternating current mains supply. Inside the light fitting is a choke which when less than perfect tends to hum. When the choke is loose internally or externally is when the hum becomes an annoying buzz.
When an audio system has a similar tone of buzzing or humming the source will invariably be the same AC mains but how it got in there is difficult to answer...
It could possibly be poor smoothing and regulation of the power supply or an accidental hum loop caused by careless design and/or poor grounding. It could be caused by being induced in the input by connecting leads that are too long and poorly positioned/screened or it could be caused by mismatch between different components causing a poor signal-to-noise-ratio.
I am not sure why it should come and go but the fact it does would indicate a power supply problem more than the other possible causes.
If the Onkyo system has it's own volume control and it is being used witha tv or similar, it is worth trying to imporove things by turning up the tv volume to near maximum and then controlling the volume with the system control.
May 12, 2017 | Onkyo HT-SR800 System
Computers & Internet Logo
542 people viewed this question
David Payne
David Payne
