Question about Samsung Cameras
I have a Samsung ES17 Digital Camera, the problem is that when I switch it on, the lens cover/shutter doesn't open, is there a solution to this problem? Thanks in advance
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 27, 2010
  • goldiejones Aug 27, 2010
    Hi
    The barrels come out OK, it's just the cover at the front of the lens won't open (it usually opens automatically), any ideas for this?
My samsung ES10 was experiencing blurring of picture?
this is either a slow shutter speed because of lack of light and you didn't have the flash turned on or a dirty lens can cause it.. if there is anything in focus it is just it grabbed the wrong thing ti focus on and the bad thing would be a bad lens... one of these is whats up
Nov 12, 2012 | Samsung Es17 Sl30 Es10 Es15
Samsung digital cam shutter not closing fully
Since it springs back then the part of the lens that opens it is broken. Then lens covers are very delicate, but usually reliable.
If it's still in warranty, let samsung deal with it. They can usually fix digital hd video cameras in a couple weeks and have service centres in major cities.
If it's out of warranty, try a bit of 100% isopropyl alcohol (see your drug store) on a Q-Tip. Swap it around the lens cover gently and then gently force the cover open several times. The lens cover should be a little wet from the alcohol, but not so much that there are droplets or puddles. Have some kleenex ready just in case of a little spill. That should help to remove any dirt inside that might be affecting the cover.
If that doesn't work and it's out of warranty, then consider repairing it. They will charge you for an estimate ($40ish). Consider replacing it, particularly if the repair cost exceeds 50% of the replacement cost.
May 29, 2012 | Samsung PL120 Digital Camera
Some how my Samsung SL820 digital camera's shutter door got stuck and it is not closing how many ever times I try to switch the camera off and on. Because of this the camera doesn't work. I've...
Did you happen to drop it accidentally? Or accidentally applied force into your camera? If yes, then there is big chance you will gonna have to replace the whole lens! If not, then it might just be dirt stuck inside your lens mechanism. To fix it, hold your camera with the lens facing the ground. Then, tap your camera repeatedly. Start with light tapping to moderate. If that doesn't work, spray condensed air directly into the lens part of your camera.
Sep 21, 2011 | Samsung SL820 Digital Camera
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
Samsung es17 lens has stopped halfway
Hi that is because you get some dust or sand in the lens mechanism wheres that block the lens to slide out
you can try to air arround the base off the lens while trying
to put on and off...
its all i can do from here
hope that will help
regards alan
Oct 11, 2010 | Samsung Digimax 4010 Digital Camera
Shutter won't close all the way
The lens cover of PSA60 opens along with the move of the objective lens. Normally the camera will sound an error beep when the lens does not end to the end position -- the lens cover is also not fully opened. In reverse, the lens will be retracted when the camera is switched off.
The "shutter" (outside lens cover) might have something stuck inside the blades or other mechanical parts that prevents the lens cover fully closed. Try to blow with a clean air (no hot air - because it can damage the electronics or plastics).
Or maybe the blades are probably not flat that may create resistance on the surface. Try to flatten the blades by hands.
Or maybe the mechanical systems need to be calibrated (by Canon service center).
My suggestion, try to exchange/trade-in your PSA60 with the latest model at the Canon center, because I have done it last year (trade-in with PS S5IS).
Aug 08, 2008 | Canon PowerShot A60 Digital Camera
Lens cover doesn't open
there is a misalignment in the shutter flaps and must be re-aligned by an experienced tech.
May 27, 2007 | Nikon COOLPIX L3 Digital Camera
Cameras Logo
184 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
