Question about Insignia Digital-to-Analog Converter for Analog TVs
Lost channels I connected the converter box, got signals for all local stations, no problem. The next day I have lost two channels, and can't seem to get them back. How do I get back my 'missing stations"
  • Anonymous May 31, 2008
    one day i checked i had a lot of channels the next day i barely found reciption even though it was at the same spot it was before. i did that channel search thing but that did not work. what do i do?
    Novelist:
    Champion:
  • 203 Answers
Try to raise your signal level by adding an amplifier to your antenna or adding height to your antenna. If your signal goes too low for some reason the box erases weaker stations. Sometimes it just relocates them to a different channel number so make sure you use channel up and down first to see if it relocated a weaker channel by itself. Look for channel numbers you don't recognize and when it locks in sometimes it will relocate them back to the original station. Hope this helps, Russmann.
Posted on Jul 14, 2008
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
Aug 24, 2016 | Olevia LT26HVX 26 in. LCD Television
Lost some stations on my Sony lcd TV.
It is a possibility if you are using a cable tv service, without a converter box, that the cable company has limited the number of station you are able to receive. It seems to be their new ploy to get subscribers to get a box since the digital changeover. I also may be that the TV's tuner memory may have to be re-programmed. Go into the menu and go through the channel scan process and see if they return. If they don'y it may be a tuner issue. An easy fix is to get a cable box!
Hope this has been helpful
Jul 03, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
I cannot get a signal with converter box and Philips indoor antenna
Try to manually enter the local DTV Station Channels, instead of letting the converter scan for channels. And try moving the antenna and then re-entering the DTV channel.
You should really have an external antenna that is matched to your local reception needs.
contact your local TV stations, their engineers will be more than happy to help.
Jun 15, 2009 | Durabrand DWT1304 13" TV
I get no stations on my tv
Use an Antenna that Provides Good Reception of All Channels
  • Most existing antennas used by consumers will provide good reception of DTV signals. (Before making any changes, try your existing antenna first to see of it allows you to receive all the stations you normally watch.)
  • For watching DTV signals, you will need an antenna that provides good reception of both VHF signals (channels 2-13) and UHF signals (channels 14-51) to reliably receive all of the digital signals broadcast in your area.
  • Many antennas are designed only for reception of either VHF or UHF signals (but not both). For example, the commonly used “rabbit ears” indoor antenna is only suitable for receiving VHF signals. To receive UHF signals, an indoor antenna should also include a wire loop or other feature for reception in that band.
  • The reception capabilities of TV antennas also vary considerably, so be sure to talk to retail consultants and look at information on the packaging and/or the Internet to make sure that any new antenna you may choose provides good reception of both VHF and UHF channels. In addition, if you use an indoor antenna and receive signals on VHF channels, you may need to use an antenna with amplification.
  • Many antennas currently being sold as “HDTV Antennas,” perform best at receiving UHF signals; some of these models state that they provide reception of signals on channels 7-13 but actually perform less well receiving those channels. If you obtain one of these antennas, be sure it provides good reception of all the VHF channels as well as the UHF channels.
  • To check for the DTV signals that are available at your location, use the DTV Reception Maps available at www.fcc.gov/mb/engineering/maps.
Check Your Connections
  • Check that your digital-to-analog converter box or digital television is connected properly. Make sure your antenna is connected to the antenna input of your digital-to-analog converter box or digital television. If using a digital-to-analog converter box, also ensure that the antenna output of your converter box is connected to the antenna input of your analog TV. Refer to the owner’s manuals of your components if you are unsure of the proper connections.
  • Ensure that your components are plugged in and have their power turned on.
  • If you have a digital-to-analog converter box, tune your analog TV to channel 3. You should see a set-up menu or picture displayed on your TV screen. If you do not see a set-up menu or picture, tune your TV to channel 4. If you still do not see a set-up menu or picture, recheck your connections.
Perform a Channel Scan
  • Digital-to-analog converter boxes and digital televisions have a button, usually on the remote control, that is labeled “set-up” or “menu” or some similar term. Press that button to access the set-up menu. Using the directional arrow buttons on your remote, scroll to the option that allows you to perform a “channel scan.” The channel scan will automatically search for digital broadcast channels that are available in your area. Consult the owner’s manual of your digital-to-analog converter box or digital television for detailed instructions on how to perform a channel scan for your device.
  • Once the channel scan is complete, you will be able to tune to the digital channels received by your antenna. You should perform a channel scan periodically to check whether additional digital channels have become available.
Adjust Your Antenna
  • Small adjustments to your antenna can make a big difference in the number of digital channels you can receive. If you have an indoor antenna, try elevating it and moving it closer to an exterior wall of your home. After adjusting your antenna, perform another channel scan to see if your reception is improved.
  • While adjusting your antenna, it may be helpful to access the “signal strength meter” on your digital-to-analog converter box or digital television to determine whether your adjustments are improving the signals’ strength. The signal strength meter is usually accessed through the menu feature on your remote control. Refer to the owner’s manual of your device for detailed instructions on how to access its signal strength meter. Remember to do another channel scan after you have adjusted your antenna.
  • Television stations broadcasting in digital use both the VHF band (channels 2-13) and UHF band (channels 14-51). Many indoor antennas use “rabbit ears” for the VHF band and a “loop” or “bow-tie” antenna for the UHF band. Make sure you are using an antenna that covers both the VHF and UHF bands and have connected it properly.
If You are Still Having Difficulty:
  • Until June 12, 2009, some stations will be operating at reduced power levels. If you are not receiving certain digital TV stations, this does not necessarily mean there is a problem with your antenna or digital-to-analog converter box or digital television. Check with the TV station to find out whether they are planning changes that will improve reception.
  • When an analog TV signal is weak or receives interference, static, snow, and distortion will often appear on the screen. Digital broadcasting will provide a clear picture; however, if the signal falls below a certain minimum strength, the picture can disappear. This “cliff effect” means that if you watch analog TV stations that have static and distortion, you may have to adjust or upgrade your antenna system.
  • Simple indoor antennas provide minimal performance that may not be suitable for your location. If you are unable to obtain satisfactory DTV reception with your current indoor antenna, you may wish to obtain an indoor antenna that includes features for better reception of UHF signals, as well as VHF, and/or an amplifier to boost the received signal (often referred to as an active indoor antenna).
  • Generally, an outdoor antenna will get better reception than an indoor antenna. However, the performance of outdoor antennas can degrade over time due to exposure to the weather. If you are having problems, check for loose or corroded wiring, broken antenna elements and that the antenna is pointed in the right direction.
  • Try to keep the length of wire between your antenna and digital-to-analog converter box or digital television as short as possible for best reception.
  • “Splitters” that are used to connect a single antenna to multiple digital-to-analog converter boxes or digital televisions reduce the amount of signal available to each device. If you are having problems, check whether reception is improved without the splitter. In some cases an “active” splitter that includes an amplifier can solve the problem.
  • If you are near a station’s broadcast tower, reception of that station, as well as other stations, can be impeded by strong signal “overload.” Consider using an “attenuator” or removing amplifiers to improve your reception.
  • If you decide to replace or upgrade your indoor or outdoor antenna, many types are available from electronics retail stores at a variety of prices. Websites such as www.antennaweb.org provide information on the locations of broadcast towers and the types of outdoor antennas appropriate for the stations you wish to receive. If you need assistance with upgrading your antenna system, check with a local antenna retailer or antenna installer.
Hope it may helps:
Regards:
VOTIT
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
Off and on signal
Welcome to the world of digital broadcasting. Chances are the antenna isn't positioned quite right for the station that's giving you trouble. It's not a TV issue or problem with the converter since other channels are fine, so it comes down to signal strength. Most of the time it's okay, but sometimes when band conditions change it gets weak enough that the converter box can't tune it. You might try shifting the antenna slightly while noting signal strength on the different channels. You'll likely find a few degrees change may give you a reliable signal on the problem channel without noticeable reduction in the others.
Feb 12, 2009 | Emerson EWL20D6 Television
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Recently installed two Philco TB100HH9 Converter boxes. Both worked well at first then both lost a major local TV station within days and cannot reprogram it into the box. Have two other TV's without a...
I just had a similar problem with this box - For the first month or two, I got the local NBC affiliate (KING-5 in Seattle) just fine on 5.1, then, after fiddling with my antenna setup, I lost it completely - NOTHING I could do would get it back. I tried a bunch of stuff - Multiple types of antenna, adding an antenna amp box, a handful of "homebrew" antennas - Nada. Yet all my other channels came in fine (although a couple were right on the edge - This box seems to need a "17" or higher on the signal strength - Some of my channels were reading in the 15-18 range, and suffering the "blockies" and sound dropout)
After hitting TVfool.com, found out that the KING digital signal is actually broadcasting on channel 48. Punched in 48.1, and there it was, clear as a bell, using nothing but a "wick" antenna (Basically, strip 4-1/4 inches of the outer braid off one end of a piece of co-ax cable, leaving the center wire alone, then plug the other end into the box) getting me a 23 signal strength. But a second or two later, the box is displaying "5.1" - Weirdness...
Reconnected a near top-of-the-line Winegard Yagi/Log-periodic antenna - VERY directional, and has some gain all by itself - and the signal jumped above 50.
Still couldn't "channel-up/channel-down" or punch in "5.1" to tune it, though - Channel 5.x was a "dead zone" as far as the box was concerned.
Re-did the "autoscan", and now, it's back to normal - I can channel-up/channel-down to it at 5.1, or I can punch it in as 5.1, or I can punch it in as 48.1, and it's all good.
So, try re-doing the auto-scan. Worked for me...
Dec 01, 2008 | Philips Televison & Video
Signal issues with my Insignia DTV converter box
As far as the antenna goes..NO. It is still an RF signal. The antenna just needs to be good for the frequency range of the stations you are receiving. The station numbers and frequency don't necessarily match like they use to. They are all over the place now.
Jun 21, 2008 | Insignia Digital-to-Analog Converter for...
Insignia Digital-to-Analog Converter for Analog TVs Logo
197 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
