How to install new pass word. - Computers & Internet
Do you mean a password for logging onto your computer? If so, I have XP and I believe it shouldn't be too different for other OS, you can go to Control Panel and select User Accounts. There it will give you several options to modify accounts or create new ones. Find your account and select it (it will probably be the Administrator account if this is your own personal computer. Mine is just called HP Owner). Once you've done this it will give you a list of options such as change the name, creating or changing a password, change a picture, etc. This will prompt you to enter and confirm your password as well as create a hint question for if you forget your password.
I hope that helps a little, if that's the kind of password you're wanting to create. GL!
Posted on May 06, 2008
Have forgot the password on my Kindle how do I install a new one
Try this;
Home > Menu > 5 clicks down > Enter (middle 5-Way) > Menu > 3 clicks down > Enter > 1 click right > Enter
Jun 23, 2017 | Tablets & eReaders
Torque spec on my harmonic balancer on my ls-1
1999 chevy Camaro 5.7
Crankshaft Balancer Bolt (Installation Pass-To Ensure The Balancer Is Completely Installed)
240 ft.lb Crankshaft Balancer Bolt (First Pass-Install A New Bolt After The Installation Pass And Tighten As Described In First And Final Passes) 37 ft.lb Crankshaft Balancer Bolt (Final Pass) 140 deg
Oct 12, 2014 | LIS 52650 Harmonic Balancer Installer
Why would my car not pass Georgia Emissions testing?
Can you remember how many miles you have driven since the engine was installed? What I mean is that if you have a good running engine and have a new converter, sometimes the easiest things are the ones overlooked. Check your air filter to make sure it isn't dirty and restricting air flow. Also check your spark plugs to see what kind of shape they are in and if they are burning clean. Spark plugs can tell a lot. If you had transfered any emission related parts from the old engine to the new, maybe one of those items has an issue or is clogged. I hope this helps. Good luck.
Jul 01, 2014 | 1992 Pontiac Sunbird
Short circuit in Stratoliner passing lamps
Hi, Doug you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable free downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help passing lamp probs
passing lights
Yamaha XV19SX Service Manual
OEM parts for Yamaha
Yamaha STAR XV19CSX Owner Manual
Jul 30, 2012 | 2009 Yamaha Stratoliner
Head torque specs for 92 honda accord with f22a1
Thanks for using FixYa.
To install:
  1. Install a new head gasket on the engine, making certain it is positioned correctly. The cylinder head dowel pins and the oil jet must be in place. Refer to the illustrations if necessary.
  2. Install the head. Lower it straight down onto the block, aligning it correctly.
  3. Apply clean engine oil to the bolt threads and the contact face of the bolt head. Install the head bolts finger-tight.
  4. On all models except 1988-89 DOHC Prelude and 1992-95 Preludes with 2.3L and VTEC engines, tighten the head bolts following sequence A. On 1988-89 DOHC Preludes, use sequence B. Use sequence C on 1992-95 Preludes with 2.3L and VTEC engines.
    1. On 1984-89 Accords and 1984-91 Preludes, tighten the bolts in two passes. The first pass should bring the bolts to about 22 ft. lbs. (30 Nm). On the second pass, tighten the bolts to their final torque of 49 ft. lbs. (68 Nm).
    2. On 1990-93 Accords, tighten the bolts to 29 ft. lbs. (40 Nm) on the first pass, 51 ft. lbs. (70 Nm) on the second pass, then tighten the bolts to their final torque of 78 ft. lbs. (108 Nm).
    3. On 1994-95 Accords and 1992-95 Preludes, the bolts are also tightened in three passes. Tighten the bolts to 29 ft. lbs. (40 Nm) on the first pass, 51 ft. lbs. (70 Nm) on the second pass, then tighten the bolts to their final torque of 72 ft. lbs. (100 Nm).
      Fig. Fig. 9: Cylinder head bolt torque sequence A
      Fig. Fig. 10: Cylinder head bolt torque sequence B
      Fig. Fig. 11: Cylinder head bolt torque sequence C
  5. If applicable, assemble the intake and exhaust manifolds to the head. Use new gaskets.
  6. If applicable, install the cam, rockers and camshaft holders.
  7. If equipped, install the EGR crossover and air suction pipes.
  8. Connect the exhaust pipe to the manifold using new nuts.
  9. Install the timing belt.
  10. Install the valve cover.
  11. Install the cylinder sensor (if equipped) and the distributor.
  12. If applicable, install the alternator.
  13. Install the power steering pump, then connect the inlet hose to the pump.
  14. Install the accessory drive belts. Adjust the belt tensions.
  15. Install the heater hoses.
  16. Install the cruise control actuator if it was removed.
  17. Connect the spark plug wires. Connect all the wire harnesses and vacuum hoses to the cylinder head, intake manifold and throttle body/carburetor.
  18. Connect the throttle control cable and/or accelerator cable at the throttle body.
  19. Connect the fuel lines.
  20. Install the brake booster, PCV and charcoal canister vacuum hoses.
  21. Install the air cleaner and intake duct.
  22. Refill the engine coolant. It is recommended that the engine oil be changed whenever a cylinder head is removed.
  23. Connect the negative battery cable.
  24. Start the engine, allowing it to idle. Bleed the cooling system. Check the work area carefully for any signs of fluid leakage or any indication of the timing belt rubbing or slapping the covers.
Sep 25, 2011 | Honda Accord Cars & Trucks
Water pump location
Here are the procedures.
WATER PUMP
Removal
1. Drain cooling system. Remove timing belt. Remove right ignition coil. Disconnect coolant hose from coolant inlet housing.
2. Remove retaining bolts and separate coolant inlet housing and "O" ring from water pump. Remove retaining bolts/nuts and water pump. Remove "O" ring from coolant by-pass pipe which fits into rear of water pump.
Installation
Ensure sealing surfaces are clean. Install NEW "O" ring on coolant by-pass pipe. Lubricate "O" ring with soapy water solution.
2. Apply a .08-.12" (2.0-3.0 mm) diameter bead of sealant on mounting surface at rear of water pump. Install water pump. Ensuring water pump engages over coolant by-pass pipe. Tighten
fasteners to specification.
See
3. To install remaining components, reverse removal procedure. Fill and bleed cooling system.
Jan 05, 2011 | 1992 Lexus Ls 400
I just installed a brand new Kettler ergometer axiom p2
If this is a bicycle computer you're talking about there's a little magnet that has to be installed on the spokes of the wheel. It passes within 1 millimetre of a receiver which should be placed on the bicycle forks. Everytime the wheel turns the magnet passes a signal through the receiver to the computer which operates the computer. If the magnet is not tight enough it will turn away from the receiver and will not work. If it passes more than 1 mm from the receiver it won't work.
Jul 17, 2010 | Kettler Cycling
ECS PT800CE-A 3.4 P4 HT CPU and DDR400 (PC3200) problems
I seem to be unable to find any information about what an ERAND error even is. No one is really identifying it on the net. One thing you may try though is to find out if the bios settings are maybe causing this. Is the system overclocked at all? Are the voltages correct? Maybe try resetting Bios to default settings and trying again.
Oct 04, 2009 | EliteGroup ECS PT800CE-A...
Emachine laptop hard disc is password protected
If it is a hard drive password, you don't. You will have to install a new hard drive, reload the operating system and all device drivers.
May 04, 2009 | E-Machines M2350 Notebook
Pass key for a new laptop
go to this site and download SIW (third one down in left freware list) and install it on the pc that already connects, it's aprogramme that allows you to see everthing listed on your pc including passwords.
when installed on the left column is secrets, click on this and you will see your router passkey listed, enter this key on your other pc.
Sep 06, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
