Question about Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750DN FUSER JAM
Hi
i have problem with phaser 7750 with fuser jam
all the time paper jam in the same spot all the time
i buy brand new fuser but still i have the same problem
Do you know what its wrong
Thanks
Jerry
  • JerryDeMoll May 06, 2008
    i dont have any code error
    just fuser jam info- all teh time
    i call to tech suport
    but they told me it can be
    1. foto sensor or
    2. Inverter Transport Assembly or
    3. Tray 2 Feeder Assembly (FEEDER ASSY)
    i clean everything from that parts
    and still nothing
    i have the same problems
    im not sure which part its can be
    do we have some tech software who can check exactly the problem
    or what part can be bad in %
  • amwtech Oct 18, 2008
    Same problem here. I bought the printer used at a liquidation sale and it did print before, since the seller had the status printout page, properly dated. I know someone who works at Xerox and she checked it for me to verify the info. I've tried all the recommended solutions, to no avail. Any ideas?
    President:
  • 2,072 Answers
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
Posted on May 06, 2008
Paper jam in area before fuser
One possible solution, check on the left hand door when you open it. There is a spring loaded exit flag on the door, these can break causing jams at the fuser.
Dec 21, 2010 | Xerox Phaser 7750DN Laser Printer
I have a Xerox Phaser 6180 MFP, and it keeps saying paper jam and there is no jam, what can I do?
Check the fuser for paper stuck in it.
Check that the 'paper out' sensor arm (in the fuser) is not broken. If it IS broken, you'll need a new fuser.
Sep 03, 2010 | Xerox Phaser 6110 Laser Printer
Problem with my Phaser 7750
Sounds like the NVM was corrupted and it can't boot properly.
Probably needs to have the firmware reloaded.
Apr 01, 2010 | Xerox Phaser 7750DN Laser Printer
XEROX PHASER 6180 SAYS PAPER JAM, I CLEARED PAPER JAM, PUT IN NEW CARTRIDGE, AND IT STILL SAYS PAPER JAM
Mar 16, 2010 | Xerox Phaser 6180N Laser Printer
Xerox Phaser 7700DN jam at fuser
Those rollers are necessary to feed paper from the fuser. Order PN 116-1759-00 which is the 15 inch long shaft w/ 4 rollers
Whit
Item, Inc.
Nov 10, 2009 | Xerox Phaser 7700DN Laser Printer
I have a 7750 xerox printer. paper keep wraping around the fuser roller and jamming. the fuser has been used for only a short time. Is this a damage unit and need to be replaced or is there something I...
Hello sir; Try to move out fuser unit, check the fingers against the fuser rollers, does it build up toner on the finger tip if it does, clean it up otherwise replace it.
Nov 06, 2009 | Xerox Phaser 7750DN Laser Printer
Xerox 7750 - Jaming in fuser
Solution 1: There is probably a very small piece of paper caught in the fuser, remove it from the machine if you can and try manually feeding paper through it.
Solution 2: Try different paper. The paper may be too weak to pass through the hot fuser, and this doesn't matter you are always using the same paper company, sometimes they change their suppliers.
Follow the link below and good luck.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(20159)
Also check this link if there is a grinding noise as well as the jam.
http://office.support.xerox.com/SRVS/CGI-BIN/WEBCGI.cgi/,/?St=299,E=0000000000024640321,K=7426,Sxi=18,Case=obj(21995)
Dec 04, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Dec 04, 2007 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
631 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
