Question about Dishwashers
Electrolux dishlex dx302 repair manual not heating
4 Suggested Answers
SOURCE: user manual for electrolux dishlex DX302
Go to http://www.dishlex.com.au/SupportCentre and then search by the model description DX302WB. I downloaded a pdf file no problem.
Posted on Oct 29, 2011
SOURCE: i have a electrolux dishlex dx302 that will not
Yes I had the same problem. One of the solder joints on the relay was cracked but hardly visable. Resoldered it and no problems.
How to do it:
Make sure you turn off the power at the wall and pull out the plug. To get to the circuit board remove the screws on the inside top of the door and pull out the front panel (where the buttons are). Press the little clips and the white box containing the circuit board comes free. Remove all the plugs and lever open the small clips holding the box shut. After you open the box pull the circuit board up and have a look at the contacts under the black little box (relay). Use a soldering iron and some flux cored solder and redo the joints. Put it all back together and turn on to see how it goes.
Worked for me.
All the best......
Posted on Aug 05, 2009
caroldon
  • 17129 Answers
SOURCE: can i please get the
Normally we are able to help you out with a solution for the fault of your machine., So please relate the fault that is seen on the machine as I can try to help. Also we are not allowed to mail personally any documents that relate to a maker as in this case Electrolux has the official right. So as a customer you can contact the support center and request for a manual, some sites offer manuals at a cost.
http://www.dishlex.com.au/common/pdf/156987653_DX301.pdf
Posted on Apr 27, 2011
Hello - I have an Electrolux Dishlex DX302 dishwasher. The washer works okay - but it doesn't always empty the contents of the dishwashing powder in to the dishwasher. It is often wet and stuck in the
If you have hard water, you should reduce the amount of detergent you use. Here's a map showing water hardness in the USA. http://www.citriclean.net/why-citriclean/
Nov 23, 2013 | Dishwashers
I have a Electrolux Dishlex DX302 and the last few washes I have notice that on the ususal cycle it is not heating (steaming) at the end. The dishes are still coming out half clean. I am not sure why the...
Doubble check the settings on your machine.
It is a long way from my heater to the washer. Hot water is essential to the operation of any model machine. I always get hot water to the sink (by running the hot water, of course) before I start the washer. I can tell when I fail to do this.
Just a thought, I hope this aids your situation.
Of course your washer heater may have failed ... You can check it using a volt/ohm meter.
Thanks for your question this morning @ FixYa.com
Jul 12, 2011 | Electrolux Dishwashers
What does the error code 50 relate to for our electrolux dishlex DX302 dishwasher?
Thanks for this information. I was able to follow triburi's instruction and just make sure all the electrical connector is connect properly. It works after i put it all back. I guess i am just lucky one of the connection come lose.
Jun 19, 2011 | Electrolux Dishwashers
User manual for electrolux dishlex DX302
Nov 12, 2009 | Electrolux Dishwashers
Dishlex 302 water not heating
My son fixed this problem with our DX302 dishwasher only this morning. Now works fine and hot. Found the solution on this site posted 11 august 2008 from dishwasher dishlex dx302wb no hot water. There are photos to help you. Take out the circuit board in the top of door and resolder the points on left hand side of green board there are 2 long solders and a half moon. The problem is at the top of the 2 long solder lines. Do not replace your element. There is a fault with the circuit boards on this model 302. I want to thank all the posters for helping me fix my no hot water problem.
Jun 26, 2009 | Electrolux 18 in. ESL4114 Slim-Line...
I need a user manual for my Electrolux dishwasher Model DX302
Call Electrolux @ 877-435-3287
Make sure you have your model/ serial # handy
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
Jun 20, 2009 | Electrolux Dishwashers
I have a dx302. its not heating the water or drying.
My six year old Electolux Dishlex DX 403 dishwasher stopped heating the water. I found comments on the internet about burnt out solder joints in the control box. A friend opened the control box and found a blackened area on the back of the circuit board. Once the connection was re-soldered the water heated again. We also found that quite a few wires leading to the control box had overheated and the insulation had melted. Considering that this dishwasher was the top model from Electrolux at the time, I was not impressed. I had previously had a Vulcan Dishlex for almost 20 years.
Thanks to those people who previously posted information about this fault.
Feb 10, 2008 | Electrolux 24 in. EDW5505EPS Stainless...
Dishwashers Logo
1,379 people viewed this question
Top Dishwashers Experts
Owen Barnes
