Question about Toshiba Satellite A300-0CF035 Notebook
While working in the laptop if it is plugged in it shut downs suddenly and restarts again and again and again. because of that i can charge it only while it is switched off
    President:
  • 2,291 Answers
Put out ur battery for some time and put it again and then try
Posted on Aug 27, 2010
I have a hp g60, i have a really weird issue. Some times my laptop stops charging suddenly and the small led next to my charging input slot does not show any light. I checked my charger its showing...
Kind of vague. It could be the port on your laptop where the charger plugs into. It could be bad, or could have a bad connection to the motherboard due to use or manufacturing defect. When the charger stops charging then it has to use the battery power. This morning the battery may have had a low charge causing the laptop to shut down. Did you notice the battery's power level before it shut down? If you are wiggling the end of the charger that is plugged into your laptop to get it to start charging again, then that is most likely your problem. Do not wiggle it , for it could fry your motherboard. If that is the case then that port needs to be re-soldered.
Jan 24, 2011 | HP G60-230US Notebook
Plugged in & not charging with new battery
Laptop not charging
if you have a brand new battery and it is not charging, check the charger you may have to replace the plug on both sides, check the cables.
you can take the charger to a TV repair shop and tell them to check it and see if there is any juice (charge) coming out of it. that is a common problem with chargers, we trip over the cable or pull it out of the laptop by accident and it brakes little by little. if there is no charge coming out you can star by checking the jack you may have to cut it and have them check it again.
if you don't want to go trough the whole testing, just tell the TV repairman to fix it it should cost you about 30 bucks instead of 80 for a new original charger or find a chinese one on e-bay
if it works for you don't forget to rate me
Apr 28, 2010 | HP Pavilion dv7-1130us Notebook PC
Sudden shut down for VGN CS16G
there is virus in bios or fan is not working properly.
Jul 16, 2009 | Computers & Internet
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
DELL D520 LAPTOP
Problem cause:
Do diagnose your Laptop try to change your battery or adapter if you have some backup device
Sep 22, 2008 | Dell Computers & Internet
My Acer Lappy turns off automatically!
This could be a heat issue. Make sure that nothing ( eg dust) is blocking the air vents.
Jan 11, 2008 | Acer Aspire 5630 Notebook
Power jack repaired now comp shuts down
the power jack plug is still loose. Tad risky opening up the shell like that, perhaps the problem was deeper than just the jack....I am curious if it can do a full battery charge if you left it recharge for a couple of hours.
Jan 03, 2008 | Averatec 3200 Notebook
Shut down suddenly
Do you get any error-beeps of any kind? Like the battery is going empty? Or does it just go off suddenly? If the first is the case, your power connector in the computer or perhaps the powersupply could be broken. It could sound like your battery doesn't get charged and your computer isn't getting power. Then it will shut down. See if the power/charge indicator is on when connected to the power grid.
If it blacks out suddenly it's probably a more severe problem, but you might try to reinstall the OS (I'm guessing windows), but only as a last resort.
Dec 06, 2007 | Computers & Internet
My 6030 has suddenly shut down!
it shutted down because (maybe)
of the folowing reasons:
1.) Error
2.) You have overloaded it,
3.) Full Memory.
try removing the battery (5 mins)
the put it back again.
then press on..
if it wont want to start.
charge your cellphone.
then try pressing the on button
Nov 02, 2007 | Nokia 6030 Cellular Phone
Toshiba Satellite A300-0CF035 Notebook Logo
51 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
